DSDPlus Fastlane Features Request
noamlivne
I really hope the DSDPlus developers will find the time to align FMPP and FMPA with FMP24 in their next version.
FMPP and FMPA lack PPM-change option, AM mode, Scan mode, Squelch and probably other features, as opposed to FMP24.
TIA
dave3825
Suffolk County NY
FMPA lack PPM-change option, ,Scan mode
I would like to see those added as well. Not every Airspy is dead on and the scanlist is very useful to me.
Would also be nice to raise and lower individual gain settings.
-L<num> LNA gain (0-15) [-L15]
-M<num> Mixer gain (0-15) [-M15]
-V<num> VGA gain (0-15) [-V10]
L and l make the VGA (listed as IF in spectrum window) go up or down ( even though L is listed for LNA ) and I have not figured how to raise or lower the Mixer or LNA on the fly. I do not use my mini with DSDPlus often so maybe there is a way
Also for Airspy, supported sample rates offered are 2.5 or 10. Airspy mini does 3 and 6 yet there is no choice for it. When I edited the fmpa.cfg to reflect 6mhz, it did not show any more real-estate at all.
@thewraith2008 tried 10 ( I assume on an R2) and same for him as seen here DSDPlus - DSD+ FMPA using 10Msps
sonm10
Central MN Monitor
Sauk Centre, Minnesota
Hey, fellas, Airspy already has a scanlist. It is FMPA.SCANLIST
Press 'S' in FMPA to initiate scan mode.
dave3825
Suffolk County NY
Help file say press s to enable/disable scanner mode.
Does pressing s a second time disable the scanner for you using fmpa?
noamlivne
Unfortunately, that is not the same fast and efficient Scan function as FMP24.
BM82557
Berkeley Co WV
...Would also be nice to raise and lower individual gain settings.
L and l make the VGA (listed as IF in spectrum window) go up or down ( even though L is listed for LNA ) and I have not figured how to raise or lower the Mixer or LNA on the fly. I do not use my mini with DSDPlus often so maybe there is a way...
Keyboard commands --
j/J adjust LNA gain
k/K adjust mixer gain
l/L adjust VGA gain
dave3825
Suffolk County NY
j/J adjust LNA gain
l/L adjust VGA gain
Lol,
Like I said, I don't use the Airspy that much. When I ran help, I did not "hit any key" revealing more commands nor did I see the DSDPlus_Help.txt that was generated after running Start CMD /c "FMPA -h > FMPA_Help.txt"
dave3825
Suffolk County NY
Saw it posted in forums a while ago so I just made a batch file.
MarkRegul
Colleagues, please advise which is the latest version of the DSD+ for SDRSharp 1700 and where to download it?
