DSDPlus - Network Repater Map
mtindor
FMP24 PRO USER
Carroll Co OH / EN90LN
Sorry to bring up an old thread but I just noticed the system I am monitoring is doing the same thing. its system 268 in the bay area. I don't understand how to look at the log file to see all the LCNs etc. I'm logging the data correctly, but I don't see any LCN's or frequencies.
can someone help?
GIven how critical this is, if you have any further questions this evening about this and the network map is still being broadcast, shoot me an email at my username @gmail.com and I'll help ya out. you don't want to miss a network map transmission if you can avoid it.
Mike
mtindor
FMP24 PRO USER
When you get a successful repeater map, and you open the file in your favorite text editor, there will be too sections. Be cautious of this.
You will use the top half to update anything on RR
You will use the bottom half when programming the DSDPlus.Sites file in DSDPlus
You don't want to accidentally scroll down to the bottom half and use that data to update the RRDB as the LCNs will be wrong.
Mike
kma371
Are you just monitoring the CC? Or do you have a multi-dongle setup? I ask because the network map might be broadcast on any slot of any LCN. So if you are just monitoring with one dongle, you might see the control report it but it can't tune to the LCN to get it.
In that case, if it's still broadcasting, tune to whichever LCN it says the network map is being broadcast on. Then let it sit there for an hour and give it a cchance to create the file.
Are you running the latest FastLane version? The latest Fl versions will write the file to the DSDPlus directory in a file called something like:
ConP 141 Network Repeater Map v020825.txt
Obviously the 141 will be different as will the v028025.
Mike
I'm using two dongles, using FMP24
Running latest fastlane.
mtindor
FMP24 PRO USER
Ok, assuming you have the DSDPlus.Networks, DSDPlus.Sites, etc. all set up and your DSDPlus knows what frequency to switch to when it sees a network map being transmitted on a particular LCN, it should automatically go there and fetch the map.
Worst case scenario, if you know for yourself which frequency is broadcasting the network map, just tune to it with the main DSDPlus receiver.
Gotta get that network map!
Mike
kma371
Mike
Well, after the trouble shooting we did on the phone and my own tweaking here, I still got nothing.
I'll be sending the raw audio to DSD and see if they can figure it out.
Thanks again.
mtindor
FMP24 PRO USER
Thanks again.
Ok. I sent you some emails this morning. We'll have to figure out what is wrong, but there is definitely something wrong. We'll have to figure out why you are getting the errors that you are getting in decode.
Mike
DSDPlus
We were able to recover some data from the supplied damaged audio samples.
100% accuracy can not be guaranteed.
Code:
   Site =  1   LCN =  1  TX = 463.77500  RX = 468.77500  DCC =  3
   Site =  1   LCN =  2  TX = 461.92500  RX = 466.92500  DCC =  4  CC
   Site =  1   LCN =  3  TX = 462.02500  RX = 467.02500  DCC =  5
   Site =  1   LCN =  4  TX = 461.50000  RX = 466.50000  DCC =  6  CC
   Site =  1   LCN =  5  TX = 461.75000  RX = 466.75000  DCC =  7
   Site =  1   LCN =  6  TX = 464.70000  RX = 469.70000  DCC =  8
   Site =  2   LCN =  1  TX = 452.17500  RX = 457.17500  DCC =  9
   Site =  2   LCN =  2  TX = 451.77500  RX = 456.77500  DCC = 10
   Site =  2   LCN =  3  TX = 461.51250  RX = 466.51250  DCC = 11
   Site =  2   LCN =  4  TX = 463.26250  RX = 468.26250  DCC = 12
   Site =  2   LCN =  5  TX = 464.38750  RX = 469.38750  DCC = 13  CC
   Site =  2   LCN =  6  TX = 464.78750  RX = 469.78750  DCC = 14  CC
   Site =  3   LCN =  1  TX = 463.76250  RX = 468.76250  DCC = 15  CC
   Site =  3   LCN =  2  TX = 461.37500  RX = 466.37500  DCC =  1  CC
   Site =  4   LCN =  1  TX = 461.56250  RX = 466.56250  DCC =  6  CC
   Site =  4   LCN =  2  TX = 464.17500  RX = 469.17500  DCC =  7  CC
   Site = 13   LCN =  1  TX = 451.92500  RX = 456.92500  DCC = 12  CC
   Site = 13   LCN =  2  TX = 464.00000  RX = 469.00000  DCC = 13  CC
   Site = 13   LCN =  3  TX = 464.47500  RX = 469.47500  DCC = 14  CC
   Site = 13   LCN =  4  TX = 464.45000  RX = 469.45000  DCC = 15  CC
   Site = 14   LCN =  1  TX = 452.75000  RX = 457.75000  DCC =  5  CC
   Site = 14   LCN =  2  TX = 463.27500  RX = 468.27500  DCC =  6  CC
   Site = 14   LCN =  3  TX = 483.75000  RX = 486.75000  DCC =  7  CC
   Site = 14   LCN =  4  TX = 483.85000  RX = 486.85000  DCC =  8  CC
   Site = 15   LCN =  1  TX = 451.11250  RX = 456.11250  DCC =  3  CC
   Site = 15   LCN =  2  TX = 452.75000  RX = 457.75000  DCC =  4  CC
   Site = 16   LCN =  1  TX = 461.50000  RX = 466.50000  DCC =  8
   Site = 16   LCN =  2  TX = 489.92500  RX = 492.92500  DCC =  9  CC
   Site = 25   LCN =  1  TX = 461.40000  RX = 466.40000  DCC =  0  CC
   Site = 25   LCN =  2  TX = 464.12500  RX = 469.12500  DCC =  1  CC
   Site = 25   LCN =  3  TX = 464.15000  RX = 469.15000  DCC =  2  CC
   Site = 26   LCN =  1  TX = 454.60625  RX = 459.60625  DCC = 14  CC
   Site = 26   LCN =  2  TX = 464.25000  RX = 469.25000  DCC = 15  CC
   Site = 26   LCN =  3  TX = 461.83750  RX = 466.83750  DCC =  0
   Site = 27   LCN =  1  TX = 463.41250  RX = 468.41250  DCC =  3  CC
   Site = 27   LCN =  2  TX = 464.97500  RX = 469.97500  DCC =  4  CC
   Site = 27   LCN =  3  TX = 451.77500  RX = 456.77500  DCC =  5  CC
   Site = 35   LCN =  3  TX = 464.68750  RX = 469.68750  DCC = 10
   Site = 37   LCN =  1  TX = 451.26250  RX = 469.93750  DCC =  3  CC
   Site = 37   LCN =  2  TX = 452.26250  RX = 457.26250  DCC =  3  CC
   Site = 37   LCN =  3  TX = 461.22500  RX = 466.22500  DCC =  3
   Site = 37   LCN =  4  TX = 461.83750  RX = 466.83750  DCC =  3
mtindor
FMP24 PRO USER
Code:
I'm going to start calling you SpinRite.
Mike
