DSDPlus - P25
vince48
Central Valley, CA.
Greetings
need your help. I like to monitor a P25 phase 1 system. I will pipe in the control channel with VB cable from my SDR and would like to follow the voice channels with my Airspy.
1. what batch file should i use for voice? Do i use DSDPlus, FMP or FMP24?
2. Or should i create a new one.
i'm trying to get teh Airspy to trunk and follow the conversation. I don't want to use dongles.
TIA
vince48
slicerwizard
Toronto, Ontario
FMPA-VC.bat to run FMPA and your Airspy
VC.bat to run the VC copy of DSD+
What SDR are you using for the control channel side?
And are you using the SDR# DSD+ plugin? If so, it will screw things up for you.
vince48
Central Valley, CA.
thanks slicerwizard
I thought you would come through. I'm running my Ettus B200 in SDR Console V3 using VB cabel for the control channel
garys
Central Texas
You need two receivers to get audio. Whether one is Airspy is one and a dongle is the other or whether both are dongles doesn't matter.
I use both set ups with no problem, but you need two receivers. You also have to make sure you enter frequency correction if you use a dongle. Airspy should be dead on and need no tuning.
vince48
Central Valley, CA.
I am using my Airspy as the voice receiver. I use my SDR which is piped in using VB cable. What am i doing wrong?
vince48
Central Valley, CA.
yes, I see all the system activity when CC is open CC window is scroling. It's when i open FMPA-VC and VC, i see the frequencies change, but no audio
vince48
Central Valley, CA.
no, I get this error message in VC DSD+
Error
VC FMPA 2.6 -i1 -o20002
Unrecoverable error encountered:
Exception number = 0xC0000005 (Access Violation)
Instruction address = 0x414007
Action: Write to address 0x1C (28)
Register dump:
DS: 0000002B CS: 00000023 IP: 00414007 EAX: 00000000
ES: 0000002B SS: 0000002B SP: 0707FF44 EBX: 0055FADE
FS: 00000053 Fl: 00010246 EBP: 0707FF50 ECX: 00000070
GS: 0000002B ESI: 0000A613 EDI: 0000000D EDX: 00000000
[Press Ctrl-C to copy this text to the clipboard]
OK
DSDPlus
Current FMPA version is 1.9
We can not help with old versions.
GTR8000
NY/NJ Database Guy
BEE00
The latest public release FPMA is 2.7.
The latest Fast Lane version of FMPA is 2.9 (released with DSD+ 2.29), and the latest Fast Lane version of FMP24 is 2.19 (released with DSD+ 2.32)
GTR8000
NY/NJ Database Guy
BEE00
If Vince is decoding a P25 control channel, he's using Fast Lane, so he should be using DSD+ 2.32 and FMPA 2.9, yes?
It's possible that he paid for a one year subscription to Fast Lane, and is using the last version he received before his subscription expired.
bharvey2
Greetings
TIA
vince48
I'm just a stone's throw from you and listen to EBRCS SW. When I'm using SDR dongles with Unitrunker and DSD+, I have the following string in my *.bat file for DSD+: -f1 -mp
The strings makes a substantial difference in voice quality,
vince48
Central Valley, CA.
thanks,
but i do not have a problem using UT and DSDplus. That setup rocks all day for me. I want to use DSDPlus as a stand alone program with my AirSpy for the voice and my Ettus b200 for the control channel.
bharvey2
thanks,
I'd think that if you can get the audio patched correctly, DSD+ should be able to decode the voice for that as well.
As an aside, did we have a face to face discussion in San Leandro about radios and scanning this past new years eve? Your RR screen name would seem to fit but we didn't discuss RR membership. I may be speaking to another Vince.
DSDPlus
Due to the slower than desired release rate, no memberships have expired.
