DSDPlus - P25
hrh17
I'm currently using the latest DSD+ fastlane to monitor my local P25P1 system with 2 dongles trunktracking through TCP which is decoding audio great with no issues, not using VAC at all because the decoding is pretty rubbish with my current set up.
Now I'm wanting to use my Radio with a discriminator tap to decode the system with DSD+ while I'm mobile. DSD+ is decoding the Control Channel from the radio with no issues. Am I still able to trunktrack with only having 1 dongle plugged in acting as the Voice Control? because at the moment none of the information from CC stream is being sent to VC dongle.
I will post my Bat settings tonight.
vince48
Central Valley, CA.
I'm interested in seeing your .bat file. Exactly what .bat files are you using with your dongle and tap radio?
hrh17
I have 4 bat files which I'm using to do trunk tracking with DSD+ and 2 RTL Dongles
FMP CC
FMP24 -i1 -a1 -o20001 -P-1 -wsl15.920 -f498.57500
FMP VC
FMP24 -i2 -a1 -o20002 -P-1 -o1 -rv -wsl245.920
DSD CC
DSDPlus -rc -T -i20001 -v4 -E -f1 -m1
DSD VC
DSDPlus -f1 -rv -T -Pwav -i20002 -v4 -E >>VC-Log.txt
M105
What does your DSD CC bat file look like when you are using the tapped scanner? Is the input set to the scanner audio? Are you including the -rc parameter?
hrh17
I was having a play around and kept the BAT the same and just added the -m parameter. But on second thought I'm thinking there's more to it. Since the radio is providing the Raw audio I wouldn't need a CC FMP24 Bat?
just the following?
DSD CC Bat
DSD VC BAT
FMP24 VC Bat?
No I haven't added the -rc parameter.
M105
Correct. All you need are those three files. The input to DSD CC should be the audio input from the mic or line-in jack you are using to feed in the tapped audio from the scanner. It still needs the -rc parameter as it will be in the role of control.
hrh17
Changed my Bat settings to the following below, It wasn't working then I finally realised I had the priority settings down to 30 from earlier. Once I changed it back to the normal threshold the Dongle began Trunk tracking and decoding audio!
DSD+ RAW TAP TRUNKING
DSD CC MOBILE BAT
DSDPlus -rc -T -v4 -E -f1 -m4
DSD VC MOBILE BAT
FMP24 VC MOBILE BAT
FMP24 -i1 -a1 -o20002 -P-1 -o1 -rv
M105
Good! I ran my setup for NXDN48 like that for a while and it worked fine but I prefer 2 dongles now that DSD+ will follow the control channel changes.
radioscan
Radio Sensei
Southern Ohio
Priority Setting
Using DSD+ with a RTL-SDR dongle to monitor Ohio MARCS-IP sites (P25).
When editing the DSDPlus.groups file, how do I set a talkgroup for LESS priority? In other words which way does priority run? 1 for less or 99?
Thanks,
natedawg1604
Colorado
Thanks,
1 is highest priority, 99 is lowest.
