DSDPlus, Scan FM Mode
DRL-XM43
Durham Region
I am using the format shown in the bottom of the quoted post and it seems to work fine with fmp24, except if it hits a control channel. It does not resume scanning. It also wont switch to AM unless AM is in the freq string.
The same format does not work with fmpa. It keeps scanning no matter what, and will not switch to am when there is an aircraft comm even if those 4 are set for AM..
What I am testing with. The first 7 are p25. 8 and 9 are nxdn (no activity yet). And the last 4 are airband.. Both fmp24.scanlist and fmpa.scanlist are exactly the same inside..
Code:
170.75000 BW=12.5 DELAY=2 Sec 1
408.20000 BW=12.5 DELAY=2 sec 2
408.17500 BW=12.5 DELAY=2 UNKNOWN
171.97500 BW=12.5 DELAY=2 BNL
171.81250 BW=12.5 DELAY=2 BNL n141
171.62500 BW=12.5 DELAY=2 Fire Island
172.07500 BW=12.5 DELAY=2 Boston
452.65625 BW=12.5 DELAY=2 E I 1
461.68125 BW=12.5 DELAY=2 E I 2
125.70000 AM BW=12.5 DELAY=2 Airport
135.80000 AM BW=12.5 DELAY=2 air
135.90000 AM BW=12.5 DELAY=2 air
129.15000 AM BW=12.5 DELAY=2 air
Control channels are not usually included because they are continuous broadcast and so the scan will hold on it indefinitely. The others will hold until voice activity ceases. I do not use FMPA so I don't know about that.
slicerwizard
Toronto, Ontario
My DSD+ version = 2.71, my FMPA version = 2.15
The most recent FMPA version is only 2.14?
The docs don't say anything about FMPA being able to demodulate AM.
Again, the docs say nothing about FMPA being able to handle AM or BW or DELAY modifiers.
vince48
Central Valley, CA.
FMPA 2.15
FMPA -h for help summary
Current working directory is "C:\DSDPlus\DSDPlus1p101"
Airspy serial number list: 644064DC238EAECD 16C463C8321D71C7
Spectrum window width: 1024
FFT size: 32,768
Spectrum update rate: 5 Hz
Step size table: 5.000 6.250 7.500 12.500 15.000 25.000 100.000
DSD+ path is "C:\DSDPlus\DSDPlus1p101"
Primary frequency list: '.\FMPA'
Secondary frequency list: '.\FMPA-FreqList2.csv'
Database search distance: 99.90 miles
Base latitude/longitude: 36.3300 -119.2920
Optimizing FFT calculations... done.
Audio output device #1 = 'SE39UY04-8 (NVIDIA High Definit'
Audio output device #2 = 'CABLE-B Input (VB-Audio Cable B'
Audio output device #3 = 'CABLE-A Input (VB-Audio Cable A'
Audio output device #4 = 'Digital Audio (S/PDIF) (High De'
Airspy lib version = 1.0.9
Airspy serial number = 644064DC238EAECD
Sampling rates supported by device: 2.5 MHz; 10.0 MHz;
Sampling rate set to 2.5 MHz
Opening WaveOut device 'SE39UY04-8 (NVIDIA High Definit'
No frequency data files found
Slicerwizard, i have 2.15
dave3825
Suffolk County NY
Just check my email and I received 2.14. Also, in the notes.txt, I only see it goes up to 2.14. Dont know what to say..
