DSDPlus.sites
n9mfk
Hi All,
is This the correct format for DSDPlus.sites the . in t site number is what i am not sure of
P25, BEE00.140, 2.30, "Site 030"
thanks Beau
relicwr
This is from my default DSDPlus.siteLoader:
; DSD+ system/site loader file
; you can edit this file while DSD+ is running
; line format:
; trunked network entries:
; protocol, networkID, 0, "network name"
; trunked site entries:
; protocol, networkID, siteNumber, "site name"
; for TIII, siteNumber format = area.site
; conventional channel entries:
; Conventional, pseudoNID, pseudoSiteNumber, "frequencyInMHZ protocol channelName"
; note: "Conventional" can be shortened to "Conv"
; recognized conventional channel protocol names:
; Analog (NFM analog)
; FM (NFM analog)
; AM (AM analog - must be supported by FMPx)
; D-Star
; Fusion
; NXDN48
; NXDN96
; DMR
; DCDM
; dPMR
; ProVoice
; trunked site entries can be copied directly from your DSDPlus.sites file
; frequency data for P25 trunked sites has to be present in the DSDPlus.P25data file;
; manually tune to P25 control channels to auto-build the DSDPlus.P25data file
; frequency data for non-P25 trunked sites has to be present in the DSDPlus.frequencies file;
; this data has to be manually added to the DSDPlus.frequencies file by you
; frequency data for conventional channels must be present
; in every conventional channel entry in this file.
; Conventional channel data does not have to be added to any other DSD+ data file
; data for any site or channel can be present more than once,
; i.e. favorite / frequently monitored channels/sites could be duplicated at the top of this file
; examples:
P25, BEE11.123, 0, "Mulberry PS"
P25, BEE11.123, 1.1, "North"
P25, BEE11.123, 2.2, "South"
Con+, 1234, 0, "ACME"
Con+, 1234, 1, "Site 1"
Con+, 1234, 1, "Site 2"
Conv, 1, 1, "119.150 AM ATIS"
Conv, 1, 2, "163.830 P25 FBI"
Conv, 1, 3, "443.900 D-Star"
Conv, 1, 4, "442.200 Fusion"
Conv, 1, 5, "462.500 DMR"
Conv, 1, 6, "455.100 NXDN48"
Conv, 1, 11, "162.550 WX1"
Conv, 1, 12, "162.400 WX2"
Conv, 1, 13, "162.475 WX3"
Conv, 1, 14, "162.425 WX4"
Conv, 1, 15, "162.450 WX5"
Conv, 1, 16, "162.500 WX6"
Conv, 1, 17, "162.525 WX7"
Conv, 1, 18, "161.650 WX8"
Conv, 1, 19, "161.775 Analog WX9"
Conv, 1, 20, "163.275 FM WX10"
relicwr
DSDPlus.sites
; DSD+ sites file
; line format: protocol, networkID, siteNumber, "site name"
Markb
Planet Earth
Hi All,
thanks Beau
Yes. In a P25 system, the RS Subsystem (RFSS) is tied to the site number and can be used to separate a large system into regional systems under the same system ID. Therefore the format is "RFSS.Site#". It will decode this way in DSDPlus and is also listed in the RRDB showing the RFSS and Site#.
D
DaveNF2G
Guest
BTW, the instructions say that files can be edited while DSDPlus is running, but it is not a good idea. If the program does an autosave while you are adding information, your new information will not be saved. Best to stop the program before editing the various data files.
blantonl
Founder and CEO
Staff member
Super Moderator
Dallas, TX
Note that we had downloadable DSDPlus.sites files for supported systems on each downloads page for Trunked Systems (premium subscribers)
mrscanner2008
Canada
but not for all type of Systems (DMR,NXDN). For the Quebec Province, I have only DSD files for P25 Renir and Hydro-Quebec.
it would be great to have the DSD files (frequencies, sites, Groups, etc) for all the systems in the DB :D
slicerwizard
Toronto, Ontario
I do it all the time and haven't noticed any issues. Edited group or radio aliases show up on the DSD+ windows as soon as I save my edits, so I even get visual confirmation that they've been picked up. The other files, like networks, sites, frequencies don't even get written to by DSD+ so how am I going to lose an edit?
ScanRite
Maricopa, Arizona
I've had it happen. Started typing something in the .radios file and then an update came in (new radio) and lost my edits. Keep in mind, I'm using EditPad Lite which is not like Notepad in that it respects the currently open file. So if an outside edit comes in, my changes are gone. Notepad will just overwrite and any changes coming in from DSD+ will be lost. Normally not an issue though.
u2brent
OAMPT
KRWDPAXKRS1
I assume DSD+ is aware of when notepad has the file open, It waits for you to close it before writing to the file. It may not have always been the case.
ScanRite
Maricopa, Arizona
No, DSD+ won't. It doesn't have an Exclusive Lock on the file and Notepad doesn't put any kind of hold on the file.
slicerwizard
Toronto, Ontario
Fixed by not using that editor, or if possible, by changing its behavior.
No, you can delete the entire contents of the groups or radios files while DSD+ is running and it doesn't "forget" what it already has in memory. Next time it updates the file, everything comes back. Super easy to test...
