I have the Radio Shack Pro 96 Scanner. In the Owners manual it says if you press 0 then text when the scanner starts up on the welcome screen it goes to the DSP factory tests. what does that mean?
I then tried to do it . I pressed 0 then text when i turned on the scanner and got this message:
Factory DSP Test Code
Enter if Yes
Clr to exit
If pressed Enter it says:
DSP Test FM
868.5125 10 u
11chz@3.6 khz
press enter
If I press enter it then says:
DSP Test 1
freq/amp 1
Failure
clr to exit.
what does that mean? why does it say that?
I have the lastes cpu 1.4 installed.
thanks Joe
Enter if Yes
Clr to exit
DSP Test FM
868.5125 10 u
11chz@3.6 khz
press enter
DSP Test 1
freq/amp 1
Failure
clr to exit.
thanks Joe
