n5ims
- Joined
- Jul 25, 2004
- Messages
- 3,993
- Reaction score
- 304
So in theory with the right set of radios, one could use FRS frequencies at a theme park and by using ANI would eliminate all possibility of bubble pack interference 100%?
Not 100%, but close. If somebody else had the same idea, was on the same frequency, tone setting, and ANI code (most families in the park probably have their mom, dad, or both there so codes like 'A13E' would be a less likely match that 'Mom' would) you may get some 'interference' that would open up your audio.
You'd still be open to your transmissions being blocked by folks that are close to you on the same channel (regardless of the tone or ANI setting) since their use of the frequency may capture your receiver and prevent it from hearing one of your family's transmissions. Worse yet, with you only hearing transmissions where the ANI code is properly received and matches, you'd never even know that they tried to call (well, until they try again or tell you later anyway).
