DUCOM Issues?
Blunt630
Chicago
Anyone using DUCOMM having issues? I have 0 transmition from all sites on DUCOMM and DuPage repeaters.
W9WSS
Retired LEO
Woodridge, DuPage County, IL USA
DuComm Starcom21
If you're not listening to them on Starcom21, then that is your issue. Not sure if any of the old 470 MHz channels are still being simulcast (or not). Fire is still being simulcast on respective VHF repeaters.
Otherwise, I'm hearing ALL the entities on Starcom21.
kevino
Database Administrator
Chicagoland
As was posted a day or so ago, the STARCOM21 Site 101 (DuPage County) control channel has changed (temporarily?) to 774.18125. Make sure you have that freq programmed in your trunktracking scanner in addition to the normal control channel (773.84375).
This is assuming that you've been listening to them on STARCOM21 before the control channel changed. If not, it's likely time for a scanner upgrade.
Blunt630
Chicago
Yep I added the alt channels... Very odd they switched to alt channels... Any word on why they changed control channels?
N9JIG
Sheriff
Moderator
Far NW Valley
Control Channels in P25 systems are usually changed because of a maintenance issue with a site's radios. A radio may have gone bad.
System admins can also change the Control Channel to test the system or to do routine maintenance.
