Durham regional police
VA3JWO
Madoc, Ontario
does anybody know where i can find the Durham regional police frequencies??? all i see on the RR page for durham, is 139.68 which is police TAC. does anybody know what their dispatch frequency is? i'm not sure if this is a stupid quesion or not.
will
IdleMonitor
They're on a iDen Mike system I believe. Someone correct me here if I'm wrong.
Unscannable sorry.
will
unlisted
Western Canada
Unscannable sorry.
I could try to correct you, but I would be wrong. (almost)
Very unscannable, very encrypted, and next to impossible to "monitor"- unless you have about $25,000.00 to spend on one item... and about 3 years in school full time to learn how to use it... Than you can listen to all the mobile calls in the area.
...Did I mention its rather illegal to own that expensive piece of equipment as well? ;)
I have heard they have a listenable "tac" channel, but its rarely used. I have heard them patched in with York quite a bit thou.. so if you can listen to York, you may hear them when they are doing something close to the region's borders.
mikewazowski
Forums Manager
Oot and Aboot
There's nothing illegal about owning a piece of test equipment and the last time I checked, it was legal to use it as well.
VA3JWO
Madoc, Ontario
getting back to durham region police, i do find it quite surprising that durham police would,'t be on the fire and public works TRS
unlisted
Western Canada
I was under the impression its legal to own, but illegal to decode/decrypt a "encrypted" transmission...? (which, iden is, from what I have been told...?)
mikewazowski
Forums Manager
Oot and Aboot
If iden was encrypted, then the service monitor would be useless without an encryption key.
In that case, Durham would have nothing to worry about therefore there would be no need to outlaw service monitors.
unlisted
Western Canada
ah neat, I learn something new everyday..
So, now I need to find a rather expensive service monitor- for dirt cheap- and so does a friend of mine... lol!
VE3RADIO
Planet Earth
it sucks! There are three sim channels but all I hear on them is digital noise.. and not P25... probably simplex iden.
exkalibur
York, Ontario
Aren't those sim channels VHF?
139.680 146.2 PL
Those 3 800MHz ones are likely simplex channels for the trunk system.
Motorola used to make an r750 that would support analog voice. But Durham isn't using that model...infact I've seen a few of them using the new r765IS which definatly doesn't support analog at all. The only "simplex" mode is the 900MHz DirectTalk mode.
According to the Motorola Product Sheet (http://www.motorola.com/staticfiles/Business/_Documents/Specifications/Static Flies/R765_Spec_Sheet.pdf), they don't support analog at all.
It's a guess, but is that 800MHz stuff perhaps Trbo?
Motorola makes an 800MHz radio that is capable of Type II SmartNet, with an upgrade path to MotoTRBO...perhaps they're going over to that for Works and Fire? Who knows.
radioman253
Toronto, ON
re: Durham Region simplex channels
I also noticed the 851.300 freq had activity lately that sounded like iDEN buzzing away.
This signal was very strong near the lake, so I looked it up on both TAFL and FCC databases.
Only Durham listed on TAFL.
Looked on FCC.gov site and bingo, there you have it...licenced to NEXTEL in Monroe County and Erie county New York across the lake from us. That is why it sounds like iDEN, because they are the same type of system.Since rebanding started in the U.S. there have been some changes to frequency use in the 800Mhz public safety band
I have heard sparse activity on the Durham licenced simplex freqs but the are definitely analog,
usually used for fireground comms in ie: large industrial area fires, or if units can't reach each other via the trunk system,
soupyfly
trenton ont
drps
will
hay how are you the fre is 142.1850...
VE3RADIO
Planet Earth
Yeah they use iDen now.. no more conventional. As for the Motorola r750 that excalibur mentioned I was talking to a officer last weekend with one.. so they definatly have some left in their fleet.. 100% digital use of course.
polkaroo
Missed him again!
Don't worry. Durham (as well as York and Peel) are all looking at a P25 system as Telus will no longer support their iDEN system past 2013 so they're forced to migrate to a real TRS.
aaaaand here comes more "oMgZ0rz p25 eNc" posts....
VE3RADIO
Planet Earth
I would rather they go provoice than P25.. we all know P25 is pretty much always going to be ENC on a new system.
