Earbuds on the G5
kc5igh
Velarde, New Mexico
Greetings:
I just bought a cheap pair of JLAB wireless earbuds for my G5.
They're working just fine, but I'm slightly bothered by the courtesy beep that precedes and follows every transmission, especially the short ones.
Is there any way to turn off those beeps?
Thanks in advance.
-Johnnie (KC5IGH)
Greetings:
Thanks in advance.
-Johnnie (KC5IGH)
Yes, which PPS are you using?
V4 E11-4
V3 D-8
Bluetooth Headset Setting > Incoming Call Notification
kc5igh
Velarde, New Mexico
I'm on Tab D-8.
I'm not receiving the courtesy beeps when I'm listening directly to the G5 speaker. That only happens with the earbuds.
What do I need to adjust?
-Johnnie
Ohhh . . . I think I need to disable the "BT Headset Incoming Call Notification"?
I'm on Tab D-8.
-Johnnie
It is at the bottom of post #2
kc5igh
Velarde, New Mexico
Hello, RaleighGuy.
I turned off the notification beep that precedes a transmission and found out I still have a notification beep at the end of a transmission.
I'm almost certain has a Unication has a setting that will disable that, but the more I listen to it, the less it bothers me. I'm accustomed to courtesy beeps at the end of transmissions.
Thanks for your help!
-Johnnie (KC5IGH)
cubn
Search, Listen and Submit
Marion/Johnson County, IN
Do you by chance have the earphones also paired with another device while listening to them with the Unication?
I was getting beeps and realized my phone was also connected to the earphones. Turned off Bluetooth on my phone and the beeps went away.
kc5igh
Velarde, New Mexico
Hello, cubn.
No, I've paired the earphones with two radios, an Icom R30 and the Unication G5, but I always make certain to disconnect them and turn off Bluetooth on the radios when I've stopped listening to either one.
The beeps were coming from a Unication PPS feature that notifies you of incoming and completed transmissions. RaleighGuy told me where to find and deactivate the feature. I went ahead and deactivated the incoming beep, and although I'm sure there's a way deactivating the completed transmission beep, I decided to leave that one alone for the time being.
Thanks for your interest!
-Johnnie (KC5IGH)
