SDS100/SDS200: Earphone
Omanzz
Massachusetts
Can someone recommend a good earphone for a SDS-100 and if so where to purchase?
Regards omanzz
jaspence
Michigan
For a cord free setup, you might look at a small bluetooth transmitter and bluetooth earbuds. For some activities, it is a lot less bothersome than yanking out the earphones when the wire gets in the way.
Omanzz
Massachusetts
Good idea, trying to keep cost down, only reason I'm doing this is my wife doesn't want to hear it ,Happy wife Happy home lol
Thanks omanzz
nessnet
What month is it?
I used to use the stock Samsung Galaxy corded earbuds.
Worked fairly well.
The Bluetooth is best, because you can then use any ANC headphones/earbuds and have noise reduction also.
BTW... If you have any Bose/Sony/(?) headphones, they can be used with a cord.
They work great.
Ubbe
Stockholm, Sweden
Some bluetooth transmitters, perhaps all, will have a time delay when it doesn't detect any audio and stops transmitting after a while. The headset then goes into sleep mode to activate battery save mode that tries to detect a BT signal for a millisecond each 2 sec or so. When used with a mobile phone it starts transmitting when the phone rings and there will be plenty of time to wake up the headset and resync between devices again until you answer the call. When scanning and a conversation starts you might loose the first couple of seconds if there haven't been any audio for a while. I.E. you would prefer to have a long delay time before it goes into sleep mode.
/Ubbe
fxdscon
¯\_(ツ)_/¯
Omanzz
Massachusetts
Worked fairly well.
They work great.
Thanks omanzz
Worked fairly well.
They work great.
Thank you omanzz
Omanzz
Massachusetts
The earphone in your link is mono, not stereo, and shouldn't be plugged directly into the SDS100.
The SDS100 uses a stereo output for the earphone jack. Inserting a mono device will short out 1/2 the output amplifier of the SDS100. A stereo to mono adaptor should be used in the SDS100 earphone jack if using that earphone.
I also read somewhere that not to use a mono plug and only use a stereo plug, even though the SDS-100's are not stereo, you would still get sound out both earphones ?
Thanks again omanzz
fxdscon
¯\_(ツ)_/¯
Thanks again omanzz
The SDS100 earphone output (as well as that of most other Uniden scanners) uses a stereo jack and is technically a stereo output in the sense that both audio channels are active, but both sides are being fed the same signal. So yes, you will hear the same audio from both earphones.
Omanzz
Massachusetts
Thanks for confirming that for.me, always get good feedback here..
Thanks omanzz aka Doug
Because it's states to use only a 3.5mm stereo plug,, stereo plug has three connections and mono has two connections.The mono plug shorts out the three connector in the scanner. Thanks Randy hope this helps Doug
There was nothing in the manual that suggested that. I searched and found a post from Upman that confirmed it. Would be nice to have that info in the manual.
On the up-side, I'm happy to report that there's been no damage to the scanner after often using it for well over a year. :D
