Edacs & Pro 96
maddogdecker
Dekalb County, IN
I have programmed a EDACS system into my scanner. Now can I enter a VHF frequency into the same bank? Putting the VHF frequency 10 to 20 channels away from the EDACS system. Or will that just screw the EDACS system up.
jehm1212
Hanover County, VA
I have the NPSPAC channels as well as several other local 800, UHF, and VHF channels programmed right next to my EDACS system. I have never noticed any problems monitoring. You should not have any trouble.
bassmkenk2508
MS Gulf Coast
just make sure that the frequency is not listed in the "ED" mode in the top right corner, for some odd reason, lol.
other than that, you will be alright.
rdale
Lansing, MI
"just make sure that the frequency is not listed in the "ED" mode in the top right corner, for some odd reason, lol."
There's nothing odd about it - if you set it as ED then it is not scanned, it is only used as part of the EDACS system.
bassmkenk2508
MS Gulf Coast
But then that would defy the purpose of even adding the frequency at all
rdale
Lansing, MI
You add the frequency because you want to scan the EDACS system _and_ that conventional freq at the same time. So entering it as FM allows that to happen - one bank but two "types" of frequencies.
