Encrypted frequencies
vashooter
Hi folks,
I'm new here and have some general questions. Thanks in advance for any advice provided to me.
1. I have no scanner other than the app on my phone. Id like to purchase a scanner to hear more public services than what is on the app (more agencies, tac channels, etc) but I don't want to spend the funds if certain frequencies will be encrypted.
Is there a way to find out if my local fire, police, etc frequencies are encrypted before I mak
Remington12G
GØT AES?
Hi folks,
What state and county are you located in? What department or agency do you desire to monitor? Budget?
rk911
Rich
Wheaton, IL
likely, yes. use the database at radioreference.com. you can drill down by state, county, city, agency. the database is maintained by volunteers who use information provided by listeners. post which agencies you are interested in a d we may be able to give you an idea.
vashooter
Chesterfield County, VA - Fire and EMS. I get dispatch on the app but would love to hear some tac channels to hear what happens on scene.
Chesterfield Co. Police
Richmond, VA Fire and Police
VA State Police
Budget is really not known. I don't need anything very fancy but maybe something that I could grow into. Remember, I am a newbie so something easy to use would be great. Maybe 300-500 range???
Remington12G
GØT AES?
VA State Police
Chesterfield County Sheriff and Richmond PD are all encrypted P25. Fire & EMS are in the clear using digital P25. The system Chesterfield uses is in the 800MHz band while Virginia State Police use a statewide VHF system. VSP is also on P25 with some limited encryption use. I would recommend a Uniden Homepatrol Series. I'm not too familiar with your area so Im not sure if Simulcast Distortion is an issue.
Remington12G
GØT AES?
vashooter
Appreciate the response. What about Chesterfield County Police Department, if you have time and are willing to check it out. Thanks!
BoxAlarm187
Level 6 RR Member (Since 1998)
Old Dominion
Shooter,
ALL law enforcement on the Richmond regional radio system is encrypted (Chesterfield, Henrico, Richmond, and Colonial Heights; both the PD and SO for each jurisdiction). All fire/EMS is in the clear, so no worries there.
VSP is on STARS (VHF), you won't have any issues monitoring them.
The HP2 is a good "beginner" scanner (but still feature-packed), but the simulcast issue is alive and well here, so you may want to explore the SDS series, if you want to shell out the additional dollars for one.
vashooter
Shooter,
Thanks,. I really appreciate the info. I'm guessing there is no legal way to unlock the encryption? Not being able to monitor PD (aside from State PD) is a bummer. That really only leaves me primarily interested in addional Chesterfield Fire / EMS channels so I can hear what happens once they arrive on scene.
With that said, is there another scanner you'd recommend?
I'm not familiar with the simulcast issue that you mentioned. Again, brand new at this.
NS9710
Petersburg, VA
Richmond Sheriff and Henrico Sheriff isn't fully encrypted, I know the jail/court talkgroups aren't, however Chesterfield county PD, SO, Richmond PD, Colonial Heights PD and SO and Henrico PD are full encrypted.
Shooter,
fredva
Virginia/West Virginia
Simulcast distortion is the result of radio systems that broadcast digital transmissions from several transmitters simultaneously on the same frequency. These signals coming from different locations on the same frequency will usually arrive at your radio out of sync with each other because they travel different distances to get there. The out-of-sync signals will produce a garbling effect when a transmission is received, or will result in the digital transmission to not be decoded at all (silence). It can be very frustrating for owners of scanners that do not have the hardware to deal with simulcast.
The SDS scanners are built to handle simulcast. Unication pagers are also used like scanners on simulcast systems, but they have some limitations. Another option is to turn a computer into a scanner - Software Defined Radio. For example, I use the OP25 software program along with a USB receiver dongle. SDR can be the cheaper option, but usually requires more setup work.
To answer your earlier question about encryption, there's no legal or technical way to overcome encryption. You would have to have the encryption keys, and those are only provided to authorized radios on the system. And they are too complicated to guess - the keys are long and have too many possible combinations.
jonwienke
More Info Coming Soon!
VA
The HomePatrols are the worst Uniden option for receiving simulcast. They choke badly in simulcast conditions where the 436 and 536 receive about 80% of traffic.
markrob7000
N4MDR
Powhatan, VA
I would second the recommendation to wait until you can afford an SDS100 or 200 if you want to monitor Chesterfield Fire&EMS tac channels. Once they switch over from Motorola Smartnet to a true P25 Phase 2 system you could also use some SDR dongles and SDRTrunk or similar programs to monitor Chesterfield for less money. I've used SDRTrunk to monitor Hanover Fire/EMS with no problems.
Ovi8caps
Powhatan Virginia
so im quite new as well and im actually listening to the same channels as @vashooter. i have bought the sds100 and love it but i feel like i should be able to listen to so much more than i actually am. i dont quite understand the p25 system ive used sentinal software to load channels but again not sure if im using the full capabilities of the radio.
fredva
We might need more specific info from you to help. What are you receiving, and what do you feel that you are missing?
K3QQN
Virginia Beach, VA 23452
Hi folks,
Yes, there is. Go into the database for the area you live in. Open up the frequency listings for the trunking systems used by you local agencies. Next to the mode letter indicator by each talkgroup there will be either a big E or a small e. Big is full time the small one indicates some transmissions will be encrypted. 73 Jim
BoxAlarm187
Old Dominion
In addition to what Fred said, where you're located in Powhatan can potentially have some effect on reception (ie: the need for an outdoor antenna).
cpohlad
Midlothian, VA
So please correct me if I am wrong, but simulcast issues occur when a control channel frequency is the same at sites nearby to each other, right? It looks like Chesterfield, Henrico and Richmond all have separate CC frequencies, thus making it a multicast site and not true simulcast (even though it's labeled as such).
cpohlad
Midlothian, VA
So I got some clarification from elsewhere and I do not have this correct.
fredva
That large radio system is divided up into three simulcast sites. Within each site are multiple transmitters using the same frequencies, thus producing the simulcast effect. In this case, a "site" is not a single, physical location but rather a collection of towers/transmitters in an area all sharing the same frequencies.
