Is the simulcast issue exclusive to P25 sites or can it also happen on Moto Type II sites as well?
Exclusively a digital issue.Is the simulcast issue exclusive to P25 sites or can it also happen on Moto Type II sites as well?
In older threads, such as Charlottesville/Albemarle simulcast, individuals were reporting reception problems with Charlottesville-Albermarle using Unidens such as the 996XT, whereas the Radio Shack PRO-106, PRO-197, and PRO-18 performed well.I haven't had simulcast issues with Charlottesville/Albemarle County at all.
When Chesapeake had Motorola system, their PD & FD were digital but had no simulcast issues at all. I could even receive the system reliably miles beyond city lines. When the city upgraded to P25, simulcast distortion became a huge issue and I can no longer receive much beyond city lines.
Most likely, the scanner falsely believes that it is receiving encrypted audio when it's not. Perhaps the signal is weak and cuts out, causing the scanner to assign the transmission to "encrypted" status. One thing you can be sure of - it's not decrypting audio that is actually encrypted. It doesn't have the keys needed to do the decrypting.Hello all! I recently got a SDS100 and was doing some quick searches through the frequency range of the Richmond/Chesterfield/Henrico system and every so often a transmission could be heard then the radio would display ENC. My problem is I could clearly hear words being spoken before the ENC would be displayed, then silence.
It sounds like the radio maybe able to decrypt the audio but blocks it because it's "Encrypted".
On my old RS Pro-96, if a channel was encrypted, you could still "hear" the channel, just sounded like some alien from Star Trek.
Is there a way to make it so you can "hear" the channel on the SDS?
Was the audio you heard heard "intelligible"? As fredva said scanners CAN NOT decrypt encrypted audio. You may have heard "sounds" for a moment before the scanner (or any digital receiver) decided the sound was not intelligible. The same way it does when it can't decode the "R2D2" sounds into understandable words. If you can understand what is being said then it is not encrypted.
Bill
Uniden didn't make it a user-configurable option to listen to encrypted audio. There is a discussion in this thread about this: SDS100: - No Encryption notification with Uniden scanners?I distinctly heard intelligible words but only for a brief second. Almost as if the SDS knows that channel is tagged as Encrypted. I just want the radio to "play the audio" regardless of whether it is encrypted or not.
