Encrypted Frequencies
DRBComm
Post Falls, ID
When getting search results in the database, is there a way to know if a particular frequency is encrypted? I obviously don't want to waste my time trying to receive a signal if it is encrypted.
On the database page for the county/system's submitted you'll see the mode column. DE is full time encrypted, De is encryption available and may or may not be in use.
If you are talking about doing a FCC search through RR database there is not.
Whiskey3JMC
Simulcastylvania, TE
Take a look at the "mode" column. Anytime you see an uppercase "E" suffix (as in DE, TE, P25E, etc) this is full time encryption. A lowercase "e" is partial encryption. Hope this helps
fxdscon
¯\_(ツ)_/¯
Hover your mouse over the "Mode" column.
DRBComm
Post Falls, ID
Thanks for the replies. I don't see an 'E' or 'e' in the mode column, but I cannot seem to hear any transmissions on those frequencies. Just noise as if it was encrypted.
W1KNE
President, Scumbag Society of America.
Southern New England
So the status of encryption is based on user feedback (via DB submisisons). There's always the chance that the department you're trying to monitor (Post Falls?) has gone encrypted since the last update to the DB, and it's not been submitted. Or you have a setting off in your receiver.
JethrowJohnson
I love P25
Marietta OH
Can you describe the noise? Does it sound like a loud buzzing noise like maybe a boat motor, or does it sound like a scrambled noise as if they're underwater or something?
iMONITOR
Silent Key
S.E. Michigan
It could be a digital mode that your scanner/receiver is not compatible with. What are you using?
GTR8000
NY/NJ Database Guy
BEE00
460.575 Kootenai County Idaho
No listing or license for that frequency in Kootenai County. Perhaps it would help if you posted a link to the listing you're looking at in the RR database so we're not all guessing here.
DRBComm
Post Falls, ID
How do I look up listing/licenses for a particular county? Is that a separate function from the database here on RR?
GTR8000
NY/NJ Database Guy
BEE00
You stated that you already found the listings in the RR database, did you not? Post a link to the page you were looking at, and which frequencies you're referring to.
GTR8000
NY/NJ Database Guy
BEE00
I am looking at the frequencies here. None of them show encrypted.
I don't see any listing for 460.575, so I assume you meant 460.475 for the PD? What are you using to try to receive that frequency, a scanner? If so, which model, and do you have the channel programmed for digital? It's listed as both analog and P25 in the database, so try locking out the analog if you have them both programmed.
DRBComm
Post Falls, ID
The reason I mentioned 460.575 is because it is vary active. I was trying to figure out what it is. With regard to 475, I have tried both analog and digital with the same results; nothing legible heard. I have used both my RS Pro-96 and SDR#.
sonm10
Central MN Monitor
Sauk Centre, Minnesota
I was going to share screenshot, but if you search FCC license database, several active licenses and (1) expired license for 460.575
ff2sherman
Plainville, CT
That looks like Mixed Mode Post Falls
Pl 77.0
NAC 770
Plus the system they seem to be moving to id De and DE so SOL
Kootenai County​
DECHEXModeAlpha TagDescriptionTag
28814708eDEKootenai Fed I/OKootenai County Federal InteropInterop
45127b047DeKootenai I/OKootenai County Regional InteropInterop
280006d60DEKootenai SO 1Sheriff 1 DispatchLaw Dispatch
280016d61DEKootenai SO 2Sheriff 2 RecordsLaw Dispatch
280026d62DEKootenai SO 3Sheriff 3 TacticalLaw Tac
288207094DEKootenai SO DetSheriff Detectives
Post Falls
DEC HEX Mode Alpha TagDescriptionTag
280176d71DEPost Falls PD 1Police 1Law Dispatch
280186d72DEPost Falls PD 2Police 2Law Tac
280196d73DEPost Falls PD 3Police 3
