Encryption Code
usmiladim
Macedonia Ohio
Good Morning Friends
Would someone please help me in figuring out what the code letters would be in Mode for frequencies that are Encrypted? I understand the FM Mode but trying to learn about what the encryption mode looks like.
Thank you
Milan
CT
You can just leave it on AUTO.
The display will then change to the correct mode when it hits that channel.
usmiladim
Macedonia Ohio
fredva
Virginia/West Virginia
If you are asking about the Radio Reference database page listings, encryption modes will include "P25e" for conventional P25 digital systems, "DE" for trunked P25 Phase 1 systems, and "TE" for P25 Phase 2 digital systems. I'm not sure of the exact letters for other digital formats such as DMR and NXDN, but they probably end in E.
usmiladim
Macedonia Ohio
You're not going to hear anything anyway.View attachment 93576
. So as long as it’s reading as FM nothing is encrypted correct? Thank you
fredva
If you are talking about what is on the Radio Reference pages, yes, that should be correct. Unless somebody in the area failed to report to RR that encryption had been turned on. But chances are, it's in the clear.
kruser
Well Known Member
W St Louis Cnty, MO
A mode that shows DE would be full time encryption of all users.
A mode listed as De (with a lowercase e) is partial encryption where some users may be in the clear while some are encrypted.
The same lowercase e applies to P25e and Te modes for conventional and Phase 2 P25 systems as well.
I'm not sure but I think DMR and NXDN systems also use an E or e in their Mode column to indicate full or partial encryption.
They may be listed like DMRe and NXDNe for example. It's been a while since I looked at that for DMR and NXDN modes.
Modes without an E or e in the mode column should mean no encryption as @fredva pointed out.
usmiladim
Macedonia Ohio
Thank you to everyone for your help. Slowing trying to figure it out so that when our local PD goes digital, I’ll be somewhat ready.
EdAzalia
AS pointed out in the Ohio Forum, Macedonia is going to the Ohio MARCS-IP system. They are not going "digital" on their present UHF frequency.
Whether they will use encryption remains to be seen.
