Encrytpion Avoid
LubeckTech
Parkersburg, WV
I am about to update the firmware in a G5 and would like to know how the encryption avoid works.
Do I have to do anything or is there something I need to do??
N6ML
There's an option for it in PPS version 0.3.14, on the D5 screen for a "Trunking TG-Monitor" knob position, but it requires the V1.20 firmware. Both are still in beta, AFAIK.
LubeckTech
Parkersburg, WV
I am installing the latest firmware right now but it is 1.10.
Is there a way I could save an encrypted talk group and skip it.
trido
Retired 32 years scanner sales
Southern In
so this enable will be only system wide and not on off per tg.i know some system have mobiles enc but not dispatch.
trido
Southern In
sorry disregard on that know systems have mobiles enc but not disp that doesnt matter not sure what i was thinking.so setting is system wide,good hope new firmware soon.
APX8000
Sarcastic Member
AES-256 secured
Will it work on trunking TG Scan or just Monitor ?
N6ML
The option is available for TG-Scan too. I've never tested it, because the TG's that are encrypted on the system that I monitor are full-time encrypted, so there's no point in putting them in a scan list :) But if you have TGs that are only sometimes encrypted, it should work.
APX8000
Sarcastic Member
AES-256 secured
Ok thanks. Yeah a few talkgroups I monitor on one system I monitor are not strapped and run in the clear for the most part. But when they flip that switch it became unbearable that I removed them from the scan list.
