External audio include own microphone
Mseda
Hi.... i want to hear my gm338 in external speaker but also i need to have own voice in ex speaker, is it possible?
Mseda
Possible, but a bad idea. Feedback happens too easily.
Actually my fire truck has 2 separated cabin when i in front cabin speak with radio the back cabin can't hear my voice they hear just reply
Mseda
so i need my voice just in external speaker not internal
Like a PA system?
You want RX audio to be routed to both internal speaker as well as the external speaker?
and
You want to be able to send your voice to a PA amplifier and out the same speaker?
Yes, it can be done, but you'll need an amplifier to drive the speaker. You can set up a button for PA function.
OK, now I get it.
No easy way to do it without tapping mic audio and feeding that to the rear cab.
Around here (Western USA) they use headset systems. The headset systems interface to the radio as well as an internal intercom system. That might be the option to look at.
Mseda
Like a PA system?
and
Not PA
Mseda
OK, now I get it.
Because of short time in agencies they have to wear their mask and helmet on before approaching the incident location so they cant use headset, it seems i have to place separate mic and amp, besides its not really important what i saying to radio the thing we need to know comes out from ex speaker, thanks
Mseda
Got it.
You could try installing a second radio, or maybe just a receiver hooked up to a speaker in the back cab.
Yes second radio would work. I want to know about functionality of accessory connector if you can help me
There's no microphone audio output on there.
There is an external microphone input that can be used as a second microphone jack, instead of the RJ50 on the front of the radio. You'd still need to find a way to tap audio off the microphone and feed it to an amplifier.
Batlabs.com might be a good source of info. They have some chat boards over there where someone may be able to assist.
krokus
Southeastern Michigan
They should not be wearing their helmet inside the truck, it is not safe. (In the USA, the NFPA standard prohibits it, and the new trucks have a bracket to hold each helmet.)
Mseda
Right it is true in your country but in my area we run and rush we cant put gloves and helmet in front of desperate people they are under roughest economic sanctions ever their wealth becoming diminish and that time their family is at risk so we must at least pretend swift act
buddrousa
Do all of your fireman riding in the Pumper have Portables?
Use what is called bone mics or throat mics then you have firegrounds coms even in AIRPACKS.
The new AIRPACKS have comports that can hook to a intercom system in the pumper NOT CHEAP but an option.
Mseda
Actually we can't buy motorola's devices anymore and the what we have are more than 8 years old because of sanctions even our batteries belong portables, expired so we headed to the Chinese radios, that is why sanctions impact US too
  • HYT-DMR-digital-radio-PD785-400-470Mhz-Hytera-walkie-talkie-Portable-radio-PD78X-PD-785-DMR.jpg
