BCD436HP/BCD536HP: External Power
jblacker
Port Huron, Michigan
Is there any external power supply for the BCD436HP scanner? I'd like something I can plug in while I'm driving my vehicle.
nessnet
Eastside of Lake WA
Remember, it is a (normal) USB input, so anything that will fit - will work.
The SDS100 is a different matter. It is power hungry and needs whatever you are using to be AWG24.
n1chu
Farmington, Connecticut
If what you are saying is you only have one cigarette lighter plug, and you already have something plugged into it, then yes... they make a plug that has two plugs. It turns your single outlet into two. Or, get yourself a Lithium-ion battery pack that has a 12 volt output.
hiegtx
Mentor
Dallas, TX
I'm using one of these:
It has a cable that will fit the 436HP or SDS100, and has enough power to both run & charge the SDS100 at the same time. (The 436HP, as already noted, must be turned off in order to charge.)
It also has two additional USB ports for powering additional devices.
