TRX-2: EZ Software
rocky28965
Otago, NZ
Some time ago, I created a program for my TRX-2 scanner with EZ-Scan.
NZ is only a small country, so I have arranged each province in separate V-Scanner Folders, 15 in all.
It works ok like that, but I would like to rearrange the order of the V-Scanner folders.
I tried renaming the CDAT_VS folders to the order I wanted them, but that didn't seem to work.
I sure there will be an easy way to do it, but I don't know it.
Any help or advice would be appreciated
Ubbe
Stockholm, Sweden
There's a curvs.dat file on the SD card but that's the current VS to use when power on.
All the data needed are probably in the config_.bin file that I believe are a zipped password protected file, as whenever a file has that underscore character it is a compressed file.
But what you can do, as you have 200 different VS file slots to use, are to open VS002 and then save to VS102 and then continue and take 003 and save to 103 and so on.
Then open whatever VS you want to be first as 002, perhaps VS105, and then copy to 002 and continue to open the next VS you want after 002 and copy to 003 and so on.
/Ubbe
