F3161T odd issues
Avery93
AL
My Icom F3161T that I have had for almost 3 years has started giving me some trouble (or maybe I'm just now noticing it).
The first issue is a delay in unmuting the audio on carrier squelch channels. It always seems to cut off around the first 100-150ms of CSQ transmissions (slightly less than it takes to decode CTCSS/DCS). Channels with CTCSS/DCS on receive seem to take the normal ~200ms to open up. I have tried everything I can think of to stop it, including making sure power save was off, disabling MDC DOS (even though MDC itself isn't enabled) and making sure channels are set to analog only (even though there's no digital board); all with no success. I have never had a problem like this on any other radio.
Another issue is a weird pulsing hum/whine noise in the TX audio when the mic gain is set at 2 or above, getting worse as the gain is increased. It kind of sounds similar to alternator whine I sometimes hear in mobiles. It isn't very consistent and doesn't do it on all channels, sometimes goes away after I transmit a couple of times, and stops when I put my finger very close to or on the mic. I believe it may be RF getting into the mic and causing problems. Also at one point I had problems with what sounded like wind noise or flutter as I pressed and released the PTT, but it seems to have gone away.
Anybody ever had any of these problems or know how to fix them?
Thanks in advance!
RADIOGUY2002
Chicago Burbs
Warrenty
If its cover under warranty send it in to get it fixed. It is RF getting back in. The antenna connector needs to be re soilder or tighten down.
Avery93
AL
I had a feeling that's what it was. Unfortunately it is no longer covered under warranty; so unless it could cause other problems, I may just deal with it since I don't use the radio very often any more.
Any idea about the delay in receiving CSQ transmissions? Also I forgot to mention that when using priority scan, the priority sample time is also around 100-150ms long. My F5021 and the F33G I had did not have nearly as long of a priority sample. Is this just inherent to the F3161?
jeatock
090-45-50 W, 39-43-22 N
Icom Repair
Send it to I-A's midwest repair station:
AJR International
300 Regency Drive
Glendale Heights, IL 60139
Phone: (800) 232 - 3965
They are the official Icom repair station for the central US, do excellent work and will have it back typically in about two weeks. Call first then send it with detailed issues on paper. They will call back with a diagnosis and charges. Flat rate repair to fix anything they consider broken, plus alignment to factory spec should be about a hundred bucks.
