Failure Rate of TK-5210 AC Chargers Alarming!
rbfarley
Has anyone had any problems with the AC Desktop chargers for the TK-5210? We are experiencing a near 50% failure rate of the power supplies, leaving the viability of our fire department portables questionable. I have heard of one other department with a similar problem. How about you?
Av8tor56
Roswell, NM
Haven't heard of this problem. We have a couple of fire departments and police departments with the radios for over a year now and haven't had a single failure.
rbfarley
Age dependent?
It is possible that only a certain years of manufacture are affected. I have noticed that Kenwood has changed the manufacture of their power supply which leads me to believe that they recognized that they had a problem. It is unfortunate that they didn't step up to the plate to their existing loyal customers.
Av8tor56
Roswell, NM
Have you talked to your dealer? If there was a bad batch of chargers then they should know about it and be able to get you replacements. What part is failing? Is it the power supply or the charging cradle?
rbfarley
Have I talked to the dealer???
That's comical!! I have talked to the dealer extensively! They have assured me that they have taked to the top dawgs at Kenwood and they say that there is not a problem, yet they agree that we are replacing them at an unusual rate. So basically what they are saying is yes there is a problem, but it is not Kenwood's problem. The issue is the failure of the power supplies. They just stop producing the DC voltage on the secondary side of the power supply, rendering our public safety, operation-critical, communication devices inoperable. I could understand if this were an amateur radio, car stereo, scanner, but we are talking critical public safety communication devices. A failure of which could likely result in the death of a firefighter. It is sad.
Astro25
Chicagoland
Are you talking about the KSC-32? I have hundreds in service and will rarely get one in with a repair across my bench....
Have not had any recent failures with new ones, either.
LTR
Ohio
I am going to ask the same thing that Astro25 asked, are these chargers the KSC-32? If so, I have had a bunch of them fail also. My dealer stated that he has had numerous customers with the same problem. In ALL of the cases, the power supplies have a date code of 0407 stamped on them. All of mine were over a year old, so Kenwood would not warranty them.
