Favorites Advice
W8WCA
/usa/oh/cmh EM89kx
Here is my list of favorites: I have it setup now with MARCS-IP In many lists
What would be a proper way to maintain all my different "subjects" so to say but not have MARCS-IP in many times?
1 Helos Discrete Freq's
2 CPD MARCS-IP
3 CFD MARCS-IP
4 FEMA Discrete Freq's
5 Nx Discrete Freq's
6 ODNR Discrete Freq's +MARCS-IP
7 ODOT Discrete Freq's +MARCS-IP
8 Business Discrete Freq's Some Trnk
9 EMS-Hosp Discrete Freq's +MARCS-IP
10 Co Eng Discrete Freq's +MARCS-IP
11 Mil Air/Civ Air Pat. Discrete Freq's
12 BCI/Jails Discrete Freq's +MARCS-IP
13 IntrAgy MARCS-IP
14 OSP MARCS-IP
15 OSU Discrete Freq's +MARCS-IP
16 RR Discrete Freq's
17 Utils Discrete Freq's + Trnk
18 Zoo DMR
19 Misc Open for Temp Discrete Freq's
20 Ohio MARCS Conv + Misc Oh Discrete
21 OSP Conv Discrete Freq's
22 MARCS Misc MARCS
23 Fr County Discrete Freq's +MARCS-IP
24 Fr Co Law Discrete Freq's +MARCS-IP
25 Misc DMR
26 Schools Discrete Freq's
27 Marine Discrete Freq's
28 CivAir Discrete Freq's +MARCS-IP
29 Feds Discrete Freq's
30 Utils Trnk
31 Ham Discrete Freq's + DMR
32 MARCS-Air MARCS-IP
33 Ohio Health DMT
73 de W8WCA
ofd8001
Louisville, KY
First rule is whatever helps you to operate your scanner with the least confusion, is the way to go.
If you are saying you have 33 Favorites Lists and MARCS IP is duplicated/replicated in multiple Favorites Lists, efficiency gains can be realized if you had MARCS-IP in its own list. For every instance of MARCS-IP, you are adding at least 2 seconds to the cycle time - more depending on the number of sites involved in MARCS-IP,
That said, you may have a method to your madness. There might be things of great interest to you on MARCS-IP, as in the kind of things you would have set as Priority Frequencies in non-trunked days. Having multiple instances of MARCS-IP gets you to scanning these much sooner, almost/kind of/sort of like priority scanning (interrupting normal scanning to check something special).
You also have a MARCS-IP for CPD and one for CFD. It would be better to have just one and separate CPD and CFD into their own departments, each department having its own department quick key. Then you could toggle department quick keys depending on listening desires. The scenario you might have is this: When the scanner is on CPD though there are no transmission, it would ignore CFD who might be talking. After CPD is done, the scanner moves on to CFD, but the CFD transmission is done.
You may also have the same deal with the OSP version of MARCS-IP. Being unfamiliar with the system, its possible that OSP uses different towers/sites than CFD and CPD. If that was the case, I'd add OSP as a Department giving it it's own Department quick key, like 99. Then I'd give each OSP site a Quick Key of 99 (same as OSP). That way, I'd turn on the OSP sites when I turned on the OSP talkgroups.
W8WCA
/usa/oh/cmh EM89kx
Thank you for the info; like times it eats up:
(And I guess I did not think about sites)!
A note I should have put in:
I Rarely listen to CPD and CFD at the same time. (But may do so now and then as I get more into this super Scanner)!
The same goes for other systems I listen to on MARCS-IP mostly one at a time.
Now and Then I do Listen to CPD and ODNR that are both on MARCS-IP
I may leave some as multi copies of MARCS-IP especially ones I only listen to just that one service - still re thinking all this!
I NEVER listen to all 33 at one time - or even close to it - I just have a lot of different things I want to see what is on "out there"
maus92
OCMD
Lol. I have one Favorites list, and use the GPS to select what channels / systems to hear. I do edit the channel / TG names and other details, which is why I need the list.
W8WCA
/usa/oh/cmh EM89kx
I am not clear on Favorite List:
In Sentinel There is a Favorites List: these are all below the heading Favorites Lists
So 33 Favorites Lists?
maus92
OCMD
Pics of my single Favorites list, and it's contents.favlist.PNGcontentsoffavlist.PNG
W8WCA
/usa/oh/cmh EM89kx
OK New Lists:
FLQK SQK DQK
1 MARCS-IP
1 Ohio MARCS-IP: Multi-Agency Radio Communications
0 Mobile Site
1 Columbus Police (25)
2 Columbus Fire (25)
3 Columbus Regional Airport Authority
4 Franklin County (25) Law Enforcement
5 Franklin County (25) Fire/EMS/Hospital
6 State Fire Marshal's Office
7 Statewide Mutual Aid
8 Franklin County (25) Emergency Response, Ohio EMA, Statewide Emergency Response
9 Medical Transportation
10 Franklin County (25) Common, Franklin County (25) Public Works
11 Ohio National Guard
12 Federal Agencies
14 ODNR
15 ODOT - Common, ODOT - District 3
16 Ohio EPA
17 Ohio Investigative Unit, OSP District 6, OSP Special / Tac
18 Other State Agencies
19 BWC
20 First Energy - Common, First Energy - Ohio Edison
21 BCI/Jails, BCI/Jails, BCI/Jails
22 Columbus Public Works (25)
23 Ohio Department of Administrative Services
24 Ohio Department of Health
2 Business
3 Civil Air
4 Feds
5 FEMA EMA Red x
6 Fire Conv
7 HAM
8 Helos
9 Hosp-EMS
10 InterAgyLaw
11 MARCS Conv
2 Ohio MARCS Conventional Systems
12 Misc Freqs
13 News
14 ODNR Conv
15 ODOT Conv
16 Ohio
17 OSP Conv
18 OSU Conv
19 RR
20 Utilities
21 BCI-Jail
22 Zoo
maus92
OCMD
Yes, but I don't have to switch between or on / off Favorites lists. The GPS finds the in-range traffic in any of the systems in the list that are not locked out. All I have to do is turn the radio on, and never touch it again - except to hold or avoid something.
ofd8001
Louisville, KY
I could see why someone would still want to turn things on/off as opposed to just "GPSing". For example, they may not want to listen to a given police agency, but do want to listen to a given fire agency.
ofd8001
Louisville, KY
I got 4 scanners, one of which is in the car. I like having all my Favorites Lists programmed the same way because I'm old and have trouble remembering more than a couple of things. With that said, I cannot remember the first thing I have forgotten.
WX4JCW
Stow, Ohio
this is how mine is set up currently, I focus on the actual Matrix in Use in the Columbus area
  • ARC_536.pdf
gmclam
Fair Oaks, CA
I don't like GPS determining what I am listening too, whether driving or not. I like to organize by State,County,City or similar. I typically want to hear a county "1 hour ahead" of me and turn off the counties behind me. Adjacent counties are optional. Here's an example. Sorry I can't seem to resize the table.
FAVORITES
00Federal USA
01Arizona
02California
03Idaho
04Nevada
05Oregon
06Utah
07Washington
WASHINGTON: Systems
00Conventional
01Justice Net
02WASP P25
03Benton P25
04Clark CRESA
FAVORITES07Washington
SYSTEM02WA State Patrol P25
DEPARTMENT00WASP
SITES80Site 001 King - Simulcast
81Site 002 Pierce - Tacoma Silulcast
82Site 003 Snohomish - King Lake
83Site 004 Thurston - Capitol Peak
84Site 005 Thurston - Maxwell Hill
