Fayette County Digital System
jason_lynch89
Mount Pleasant, PA
Where are the talk groups for the new Fayette County system? I am not able to find the talkgroups, or at least the proper ones. Before I was able to tell which Tac channel they were on, now I cannot?
fred4405
Washington, PA
Fayette County
On Wednesday they went live with the new P25 system. Does anyone have the programming information for the P25 system? I have not been able to find it anywhere yet..
talviar
Uniontown, PA
What are the control channel frequencies?
ICORRS (Inter County Regional Radio System) Trunking System, Multiple, Pennsylvania - Scanner Frequencies
I will give a caution. . . . At this point I would not program in 860.4625 into your scanner. I would put the other control channels in for now. 860.4625 is still in rotation on the Smartnet Analog system. Your scanner may or may not be confused with 2 control channels at almost equal signal strength in dis-similar trunking formats. Some units it shouldn't be an issue but some units you select Motoroa/P25 to decode either a Motorola Smartnet system --or-- any of the P25 systems. You put 860.4625 and 860.2375 in and might be picking up more than you anticipated or nothing at all.
The freqs listed in Radio Reference for Fayette's portion of the P25 Digital trunking system as listed on the page above are 100% true and accurate. Verified by me.
T
jason_lynch89
Mount Pleasant, PA
icorrs (inter county regional radio system) trunking system, multiple, pennsylvania - scanner frequencies
i will give a caution. . . . At this point i would not program in 860.4625 into your scanner. I would put the other control channels in for now. 860.4625 is still in rotation on the smartnet analog system. Your scanner may or may not be confused with 2 control channels at almost equal signal strength in dis-similar trunking formats. Some units it shouldn't be an issue but some units you select motoroa/p25 to decode either a motorola smartnet system --or-- any of the p25 systems. You put 860.4625 and 860.2375 in and might be picking up more than you anticipated or nothing at all.
The freqs listed in radio reference for fayette's portion of the p25 digital trunking system as listed on the page above are 100% true and accurate. Verified by me.
T
1002 dispatch
1003 fd 02 cmd
1004 fd 03 ops
1005 fd 04 ops
1006 fd 05 ops
1007 fd 06 ops
1008 fd 07 ops
1009 fd 08 ops
1010 fd 09 ops
1011 fd 10 ops
1012 fd 11 ops
1013 fd 12 ops
fd 13 xpatch ????
1243 ma 14 ops
1244 ma 15 ops
