Yes it will. Get your dealer to add it to the FSS file.My XL-200p won't do wide band on 70cm. Color me bummed.
When is the last time that some ham showed up on your system?
To be clear about it, I'm not advocating for the end of radio licensing. I think licensing is an important part of regulation and regulation is necessary.
But enforcement should be a matter of intelligent decision making. Enforce those cases where there is an affected party. Not in those cases where there has been no harm done, and nobody has complained. Absolutely every licensee has the right to file complaints about unauthorized users interfering with his system or licensed frequencies, but in that case, there IS an affected party.
As for programming amateur frequencies into a Part 90 radio, since FCC type acceptance is NOT required for amateur service transmissions, that radio's type acceptance is a moot point on those frequencies. You might argue either way for that. But in practice, when is the last time you heard of an enforcement action for that reason? I can't recall having ever heard of that happening. Of course I've heard of enforcement in the reverse scenario, where Part 90 channels were programmed (to transmit) in a non-type-accepted amateur radio that had been "opened up".
Has there been a sudden surge in prosecution of victimless radio mis-use? I was under the impression the FCC has never had enough budget to enforce anything but the most serious cases (or exemplary ones, like the present subject).... But enforcement should be a matter of intelligent decision making. Enforce those cases where there is an affected party. Not in those cases where there has been no harm done, and nobody has complained. ...
Pirating on trunking systems gets their attention.Has there been a sudden surge in prosecution of victimless radio mis-use? I was under the impression the FCC has never had enough budget to enforce anything but the most serious cases (or exemplary ones, like the present subject).
There's one way, IMO, to get involved in those: *listen*, watch, and stay away from the scene unless you're supposed to be there. Enjoy the scanner feed, and call 911 if you see the dude.Actually less that 5 years ago. We had a missing person search and a ham got on our operations channel. He was not a member of a SAR or Fire/EMS unit on scene but felt he needed involved.
I have been all over the lower 48 states and never had an issue using 445.925, 445.950, 445.975, 446.025, 446.050, 446.075 MHz for simplex using ether a mobile, hand held, analog or digital. Always decent coverage in rural or urban environments.
Yes on this! If you search 5MHz lower in frequency than what's listed above you will find probably hundreds of repeaters across the US where the freqs are repeater inputs and I'll bet many of them are noise squelch operated.??? Those are repeater input freqs in most of the US (except at least SoCal, where they are outputs). If you're not listening to the repeater output (5 MHz lower), you wouldn't necessarily know if there's an "issue".
Thanks guys for the information.Yes on this! If you search 5MHz lower in frequency than what's listed above you will find probably hundreds of repeaters across the US where the freqs are repeater inputs and I'll bet many of them are noise squelch operated.
If the time comes, programming this fleet of Baofengs to transmit on whatever frequency is indeed a trivial matter.
One admission: some of my ham units are programmed to transmit and receive on 156.800 MHz. Yes that is the marine emergency channel (16). No I don't transmit on it though the one night a small boat tried to run me down on my kayak, I probably should have. Yes it *is* legal to transmit on that frequency in an emergency, but my wife and I both had our hands full with evasive action.
I keep that frequency programmed because when just a seven by two foot fiberglass tub separates me from the drink, things can go south in a real big hurry and swimming ten miles to shore was not what I had in mind. Especially when I'm surrounded by orcas.
The reality is that you're more likely to get a ticket for jaywalking than you are for making unauthorized use of an empty channel for occasional short range communications.
There are two kinds of unauthorized transmissions: Those that cause interference or harm to licensed users, and those that can not be demonstrated to have caused any harm to any service or any users.
If I ran the zoo, the first category would be subject to aggressive enforcement, and the second category would be studiously ignored as a waste of limited enforcement resources.
Truth is, there are plenty of slices of spectrum to play in.
Amateur Radio
CB Radio
FRS
GMRS
MURS
Part 15
Yet there are those that are still not happy and will decide they need to hop someone else's fence and play in their yard.
"If I don't get caught, it must be OK"
I get it.
I'm sure Mr. D. B. Cooper felt the same way with all that money.
But we all know that the FCC doesn't have the resources or desire to chase most of this stuff down unless it get stupid blatant.
As for the original post in this thread, the individual got a major case of the stupids and kept it going long enough that he could be easily tracked down. A trained amateur radio operator, God of the Electromagnetic Spectrum. What could have possibly gone wrong?
Whackers gotta be wackin'Actually less that 5 years ago. We had a missing person search and a ham got on our operations channel. He was not a member of a SAR or Fire/EMS unit on scene but felt he needed involved.
And 900mhz spread spectrum. Such as these little darlings....
Motorola DLR1060 6 Channel Digital 900 MHz License Free Business Radio
The Motorola DLR1060 is a versatile and reliable radio that is perfect for a variety of businesses. With features like private reply, call all available, and direct call, you can easily reach the people you need to. The radio also has a long battery life, so you can stay connected even in long...www.toolup.com
And, relying on a Baofeng for contacting the USCG when you are out with your wife, at night, many miles from shore still has me scratching my head...
Not in Indiana.Those are repeater input freqs in most of the US
Is repeater book more inaccurate than usual, or do you mean "some parts of Indiana", though it shows very little in the bottom part of the 440 band, ~440–441.2?Not in Indiana.
I'll address signal500's statement rather than comment on what's listed in RepeaterBook.I have been all over the lower 48 states and never had an issue using 445.925, 445.950, 445.975, 446.025, 446.050, 446.075 MHz for simplex using ether a mobile, hand held, analog or digital.
