FDNY EFAS
ocguard
PA/MD
This question broaches the radio topics, but also delves lightly into the IT end of things as well.
A few questions about FDNY's EFAS system.
1. I've read that the EFAS system displays the member attached to the radio's NAME as well as riding position. Assuming that every member doesn't have their own personal radio issued, how does the EFAS system correlate a name with the member. I'm assuming members are signed into an accountability system at the onset of their tour that links their name with the radio they're using, which in turn integrates with the EFAS.
2. In regards to the swapping out of a broken radio, does the radio replacing a broken radio get programmed with the broken radio's ID number, or is a new number for the replacement radio added to the EFAS system?
3. Who is responsible for after-hours handling of broken radio equipment in the FDNY?
carlos7801
Lawrence MA
1) FDNY has an ID scheme for each Engin, Truck, Rescue, Special unit, ETC and riding position. Each Radio ID is an assigned to a specific position and the EFAS just has a compiled list of all IDs so they’re aliased via the software, pretty simple.
2) yes whatever gets broken in field, and the unit needs to be replaced, the radio taking its place will be assigned the same rider position the member is supposed to have.
3) Either FDNY RRMs or Directly to Moto
ocguard
PA/MD
Thanks so much. So the EFAS doesn’t show member name? Only company and position?
55engine
Hartford County area
question about this does anybody know how to get the MDC 1200 working on a Apex 7000 I put in other conventional channels for the jersey area and their Radio IDs are working in FDNY is not working
62Truck
Ordinary Subscriber
Ø
as @SCFDCOMM mentioned, T\they are not using MDC1200.
They are using TPS (Tactical Public Safety) which is P25 Data transmitted before or after analog voice. This allows them longer RID numbers
cackis
Orange County & Bronx NY
I've been out for a couple of years but I'm pretty sure EFAS displays the members name assigned to the riding position. Each tour the officer is responsible for submitting an electronic riding list for his/her company which is called an EBF4 and keeping it updated if any changes occur to who is riding in a position during the tour. This interfaces with the EFAS system to provide the members info.
APX8000
Sarcastic Member
AES-256 secured
The rigs are using MDC on the dispatch channels.
If anyone has a running list of alpha tags for MDC on the dispatch channels, send me a PM. Save me some time creating one.
And yes, I'm well aware of the pattern it follows like 5032 is Engine-32, BC01 is Battalion-1 etc. but there are some miscellaneous in there I'm seeing.
paul612
mass
If you are using a motorola APX there is a program that is excel based and easy to use. Then it saves as an xml then you can import it into the radio. I've used it before, not for FDNY but other stuff. That is probably your best bet.
You'll be able to build out the most of them. Same for the TPS astro ids.
MonsterNik31
E-staffing was also extended for the FDNY EMS Rescue and HAZTAC Crews.
