FDNY Problem?
sogs
New Bedford, MA
Is anyone not hearing FDNY borough dispatch's? I'm hearing the combined borough channel but not the individual ones for the last two days.
AK9R
Central Indiana
Are you referring to a live feed of FDNY dispatch or are you listening to those channels directly?
a727469
Maine
Same here. Not hearing any boroughs. Tried OPENMHZ also and nothing even though NYPD is coming in. Interesting.
sogs
New Bedford, MA
Is your screen similar to this? Manhattan, Brooklyn and Queens show the green bar moving only slightly when there is no broadcast. It does this all the time even when it was working. It's like the audio feed from the provider is open but the scanner is off.
a727469
Maine
Not sure about what you are looking at but I usually use openmhz for FDNY and it now only shows Manhattan with brief 2 or 3 second bursts with no audio. Nothing on the other boroughs. Tried to hear the 2 nd alarm this am and nothing. Listened on the other multi borough feed which was ok. Not sure what is going on.
sogs
New Bedford, MA
I'm using the Broadcastify dashboard. I've no clue what you're using. Apparently something is wrong.
sogs
New Bedford, MA
Still the same. I reported the problem to all the feeds and no responses.
a727469
Maine
I assume you mean reported to the feed provider since broadcastify or openmhz are not responsible for the feed itself.
sogs
New Bedford, MA
Still having the same problem. I reported it to the feed provider(s). Anyone have any ideas?
dave3825
Suffolk County NY
Relying on a feed can be a pain. If you’re in the area consider a scanner or some sdr dongles so you can be in control of what you listen to. Otherwise give the feed providers time to reply.
sogs
New Bedford, MA
Each feed indicates it is online and there are X amount of listeners on each feed. It's been three days.
sogs
New Bedford, MA
I just tried it now and they are all working. Queens is very low though. I just wish someone had an idea of what might have been wrong.
a727469
Maine
No Brooklyn…manhattan with hum. Queens low..Bronx and SI OK
not sure where the OP is but I am 300 miles from nyc so the feed is great to have. Also OP said he did try to contact the provider but not sure what answer he may have received. I am just thankful for any feed that might be available with the understanding that it is not always 100% reliable.
