- Joined
- Sep 8, 2002
- Messages
- 4,053
- Reaction score
- 1,447
The problem with interoperability is obvious...we're dealing with FOUR different bands,
or actually, FIVE, if you consider that the UHF band goes as low as 383 MHz and as high as
520 MHz and no radio currently on the market handles that full range by itself. Only the
700/800 bands are close enough together that one radio can cover both, at least until
someone makes another multi-band radio option.
And even if everyone is on the same band, there's still unique system data. Unless you're
already part of a multi-site, wide area system, you're going to have separate personalities
for any other radio system. Do you have enough radio memory to handle a large number
of systems? Is it very user-friendly to have to contend with that many radio systems that
you have to choose from? Who gets to use ALL these systems? Who's got that authority
and who's going to manage ALL the required system and encryption keys for ALL those
systems and keep them ALL updated for ALL concerned?
It's a pretty hairy situation at best. But at least, with P25 interoperability, the situation
is less hairy than it was.
If I did join the standards group, I'd recommend setting up a nationwide network of
VHF repeaters. Set a PL tone, go analog, clear voice, and stay that way. Keep it simple.
All this digital technology has dramatically raised the cost of radio equipment and systems
but it hasn't made it WORK BETTER.
Elroy
Elroy
