Feds pushing Project 25
WayneH
Forums Veteran
Your master site
zerg901 said:
I dont think that digital has greater range than analog.
There's no range difference as they propagate equally but you'll have better clarity than analog when on the outer reaches of the coverage area. The digital allows for better recovery of the voice in those areas.
ff-medic
The Appalachians - Next to the tent and campfire.
Exactly. Right on the mark.
FF-Medic !!!
10-42
N
N_Jay
Guest
All radio propagates the same, but the threshold for acceptable reception is lower, so the RANGE is further.
WayneH
Forums Veteran
Your master site
Useable range. Whatever! You sound just like a PITA engineer.
N
N_Jay
Guest
And you sound like a PITA "want-a-be" engineer!:lol: :lol: :lol:
WayneH
Forums Veteran
Your master site
I need to start quoting more manuals and specifications before I can be classed as wannabe. :lol:
zerg901
yup
If digital has better range than analog - how much better is the 'range'? 10 inches - 20 inches - 1 %? Peter sz
N
N_Jay
Guest
Yes, No, Maybe!!
Have you ever done any coverage testing?
Are you familiar with the statistics involved?
If not, then there is no way to give you a meaningful answer.
Best guess right now is 1.5 dB over 25 kHz FM, and about 3 dB over 12.5 kHz.
D
DaveNF2G
Guest
Aha! The truth at last!!! :D
Whether digital or analog is "better" or has "greater range" depends on the individual characteristics of the location, power output, antenna height, brands and models of radios in use, operator skill, and so on.
N
N_Jay
Guest
No!
Given all things being equal (Other comparisons are meaningless), the AMOUNT of greater range can only be described statistically.
N4DES
Retired 0598 Czar ÆS Ø
South FL
Digital doesn't give you greater range. It gives you a higher quality signal within the footprint of the target system to include areas where analog is "noisy". Comparing SINAD and BER is not an exact science even though the IEEE tried their best in order to show the positives and negatives of each technology and to further document Acceptance Testing of Mixed Mode Systems.
One thing I did find in the early stages of the NEXTEL fiasco is that two XTS3000's operating in the same capture area of an iDEN site where an analog TG was severly interfered with, a digital TG steered to the same channel trunked worked without any issues. It was an unscientific test done on the fly prior to NEXTEL re-tuning the site but it sure showed us how well the BER worked in P25 vs the human ear in this situation.
N
N_Jay
Guest
OK, lets not get too far down then semantic argument.
For all intents and purposes, "range" is used to describe how far a USABLE signal goes (since in theory, the signal goes forever, it just keeps getting weaker until it is indistinguishable from the underlying noise).
Given that all other factors are the same, a P25 signal can be decoded into usable voice communications at a level where you can not demodulate analog FM into usable voice communications. Hence, It has greater RANGE.
As for comparing SINAD and BER, yes it is an exact science, but the results require well documented statistical analysis. Most people want "simple" answers and are therefore disappointed.
Note that I did not tell Zerg that "there way to get a meaningful answer."
I said; "there is no way to give you a meaningful answer."
WayneH
Forums Veteran
Your master site
Digital will give you at least equal to if not better usable range than analog. If it doesn't, something is engineered - or probably programmed in either the mobile or repeater - wrong.
It's hard to answer because it also involves how the user interprets what he or she hears. That's a variable so you can't give an exact answer.
zerg901
yup
Does anyone have any documentation that shows digital radio systems have better range? Does anyone know of any digital systems that required fewer radio sites, or lower ERPs, because they were digital instead of analog? Peter sz
N
N_Jay
Guest
TSB-88B has some of the statistics.
That is a little tougher. You would have to do two designs, and there is no good reason to do all the extra work.
16b
Central Ohio
N_Jay said:
but I am not the one complaining on there decisions.
I'll try to make this as simple as possible.
We're not complaining about their decisions.
N
N_Jay
Guest
Oh my god, you found a typo!!*******!!
n7jei
New Mexico, USA
Where did the "digital is less expensive than analog" discussion go? Did I miss it? Looking at news articles about the cost of new digital trunking systems, the prices seem rather astronomical. And now there is talk of those systems having an expected life cycle perhaps 30% less than first expected (and budgeted by agencies). My opinion (and it's not worth anything except to me) $$$$$$$$$$$$$$$$$. (Translated: vendors are making mega-bucks off this, with no end in sight.) 'Tis the american way I guess.
WA4MJF
Not a typo but rather the wrong word. A typo would be like "tehir", for example.
In the instant case, it is just wrong or maybe from the appendage of the name calling,
the result of ignorance. I've found in my many years that folks who resort to
name calling are usually those of lesser minds.
