On Transfer Rate in the Encoder Settings, it keeps trying to connect every 30 seconds. I have good audio through line in. The encoder is MP3: 16 kbps/22050Hz/Mono. It's showing as online. I also changed it to 5 seconds.
FYI, when using Oddcast, if it keeps trying to reconnect every 30 seconds and the web site shows that your feed is online, the problem is usually that there is more than one copy of Oddcast running on the PC at the same time. One copy is encoding the audio and sending it to the server just fine and the other copy is the one you see that keeps trying to reconnect (and keeps failing since the other instance is already connected).
