FHP Unit Radio ID's
Bolt21
Spark Chariot Driver
Punta Piñal
It's been about 15 years since I've listened to FHP on a scanner. However, I picked up a little bit of chatter on one of the "Mobile" freqs the other day.
Can anyone refresh my memory as to how units are ID'd on the radio? (For example a Hillsborough patrol unit would be 1Bravo5) I want to verify if it's really FHP I'm hearing.
Thanks!
Vern
Union County, GA
I'm not sure if they still do it this way, but the way they most of the State LE agencies USED to do it many years ago was by the Trooper's ID number, not by any kind of zone or sector number. So when you hear the dispatcher talking to a Trooper with an ID number of "one thousand (and somethin') you know he's probably not the most senior Trooper on the road, whereas some Trooper with an ID number of, say 500, has probably been on the street for 15 years.
The strange thing about that is that the ID numbers are "adjusted" by seniority periodically, like every year. So even if you did have an accurate list it would be obsolete the next time the ID's are adjusted. As the FHP's staffing decreases due to resignations, retirements, etc., those old ID numbers leave gaps in the ID number system. When they "adjust" the ID list, everyone's number moves lower on the list to fill in the gaps and new hires get the next sequential (higher) numbers. So, in theory, the Trooper with the lower ID number is the more senior Trooper. (for whatever that may be worth)
They may have a set bank of ID numbers reserved for different ranks, with the big bosses having the numbers below 50 or so... and Lt's, Sgt's, and other supervisors having blocks of numbers after that. But even in those blocks, I think they used to be based on seniority, with lower numbers being senior folks.
In the days before the Troopers had MDT's, I used to hear them come into service from home with their ID number and the dispatcher would tell them what "zone" they were working for that shift. But they would always use their radio ID number for their comm's...not their zone number.
Again, I'm not sure if they still do it that way but hope that helps answer your question. I believe that the Fish & Wildlife folks did it the same way.
Bolt21
Punta Piñal
Com-4 said:
1Bravo4 is a Hillsbough Co Sheriff unit, NOT FHP.
I realize that - I was using that as an example in case I didn't make myself clear.
Thanks for the info, Vern!!!
gccflscan
Banned
FHP ID's
FHP ID are upto 4 digits in length starting with 1 to xxxx which will be the last trooper hired at the time issued.
So 1 is Col. Christopher Knight, 2.... all the way to 1710...
EVERY YEAR they are renumbered starting with Col. and then down to the last trooper.
Same goes for dispatchers starting at T1 to Txxx the last dispatcher hired. Again, renumbered every year starting with Chief Duty Officer Margaret Goodman.
The lower the number the bigger the ego,err..rank.
dic
Weston, FL/Swampscott MA
The above posts are corerect.
The ID numbers change every January 1, and drop down to the next 100.
The reason I know this is that assigned to the Florida Turnpike (Ft Pierce sector) is the best looking female trooper I have ever seen.
She has a very distinctive radio voice.
I saw her in the Ft Pierce rest area in 2003, and turned on the scanner to see if I could her her clear from the rest area. I did. Her call sign began with 14.
I happened to see her on the Turnpike on Jan 1 2004, her call sign began with 13.
A year later it was 12 and this year it is 11.
Not the greatest REASON for knowing this , but the facts are helpful...
N4DES
Retired 0598 Czar ÆS Ø
South FL
Won't be able to hear them on the radio anymore. EDACS went live in many parts of South Florida today.
