Finding Frequencies
cpohlad
Midlothian, VA
What methods does everyone use to discover frequencies in their area? Spectrum analyzer or frequency counter? I know Close Call can also be helpful.
Whiskey3JMC
_/|\_Surf's up, Happy DX!
Simulcastylvania, TE
I run custom searches on my Uniden x36HPs and my SDS100 regularly to detect new (to me) stations wherever I go with my radios. Indeed Close Call can be helpful but at times it can be a nuisance as it typically detects ANYTHING emitting a radio signal (regardless if there's voice or not) so I seldom use it unless I'm hoping to capture an elusive simplex user
dave3825
Suffolk County NY
For finding new stuff in my area I mostly use Sdr# with the frequency scanner plug in. I have predefined ranges set and I scan them. When I find something known., I lock it out of the scan. When I land on something that was not known, I id it and then lock it out.
cpohlad
Midlothian, VA
I've tried using that plugin but I can't seem to figure out exactly how to set it up properly.
dave3825
Suffolk County NY
I am using it on sdr#1742 and have the dll and magic text somewhere. I did not care for the newer versions of sdr and believe the older plug in does not work with the newer versions.
JethrowJohnson
I love P25
Marietta OH
I use the Discovery Modes on my BCD436HP. So far I've only used the trunking one to find new channels on the Ohio MARCS-IP network, but I'm planning on running a few Conventional Discoveries to see if there's any frequencies in my area that aren't in the database.
ladn
I'm in SoCal, which, to say the least, is a frequency rich environment.
I use a combination of methods:
  • Scanning existing (known) frequencies like the itinerants, MURS and FRS
  • Scanning between two fixed frequency points (ie. 450-455 MHz)
  • Information gleaned from here at RR, other Internet sources, and FCC records
  • General institutional knowledge I've gleaned from having been involved in scanning and the news business for 40+ years
dlwtrunked
Yeah but one drawback here is the need to lug around extra hardware with you. Not always feasible when you're mobile
Carrying a simple dongle or AirSpy with one of the apps for an android phone is less that carrying the alternatives so in that case, not extra hardware but actually less.
racingfan360
Exatly this. Custom searches to find new frequencies, scanning them them to find out who's using the frequencies. The other pitfall with close call is that it'll always miss simplex/mobile DMR.
Airdorn
Cordova, TN
Hmm, can you name 1 or 2 of those Android apps? I'm getting sick of lugging this laptop around in my truck. ;)
