firmware downloading problems- need help
frank125
hello i will try this again. i have downloaded several downloads from gre website. i wanted to get original firmware, so i could get my vscanners back i deleted all preprogramed info. rite know anything will do just so i understand what the hell im doing. ok know after downloading i get off internet. go to my documents where downloads are saved. next go to the download i want- say vscanners. unzip the folders after it shows they were succesfully unzipped. know this is where im lost i tried to do the sample downloads it shows you can do. it shows that the scanner has no responce or no responce from scanner. im using windows -me its showing i have two com ports labeled 1-2. dont know which one to use. this is really turning into a freakin nightmere. could someone please give me some easy instructions step by step as to what ineed to do. this is for the psr-500 thanks in advance frank. also does the scanner stay on or off. i did download the instructions but i just dont get it. please some help thanks again
spooney
Indiana
If you are trying to do the CPU upgrade you have to turn the scanner off then press and hold the "PGM" button while turning the scanner back on. The display will read:
uP Boot Ver:F0.1
uP Appl Ver:F1.0
CPU SW Upgrade
Wait for PC/IF
Now you are set to receive the upgrade. If it doesn't work on COMM-1 then go to COMM-2 and try it again.
Swipesy
Northern Ohio
Restore
If I understand what you are trying to do you are not trying to restore firmware (CPU or DSP) but you want to put back the Vfolders you erased.
If that is the case then I would suggest if you do not already have, acquire either PSREdit or WIN500 software (you can try free) and load the vfolders back with the software, it will be a snap.
As to getting the com port, I have not used ME in years but make sure that the USB Port in your device manager aligns with the port in the software.
DaveIN
Founders Curmudgen
West Michigan
You may also need to install the driver for ME that is included on the CDROM with the radio.
