First Mini SSB-capable CB
WSAC829
Wisconsin Radio 225
EN64ak
I can’t tell a difference just yet. I switched them out in my truck so we shall see.
I’m assuming you got the newer QT60 Pro. If so there are some noticeable differences. Off the top of my head: VHF RX added. Dimmer added. Adjustable FM deviation added. Adjustable SSB TX bandwidth added. VFO mode added. CTCSS/DCS scanning added, and a few more things. Some items are only selectable/adjustable via the programming software, so make sure you hook it to a PC at some point and take a look. (y)
slowmover
Fort Worth
@jcrmadden first DIY bracket for DRX-901.
I’d want it slightly back and higher.
It’s difficult to convey the difference the right speaker can make when it’s in the right location.
When I’m trusting to the veracity of what I’m hearing in deciding to take this 39.5-ton combination vehicle off the Interstate onto a secondary route its due to the trustworthiness I detect in the other mans voice and phrasing.
I’m not in a position to wait . . the situation is worsening by the second. The decision involves plenty of following decisions (judgments) to be made. I’m making irreversible decisions as we speak.
Have the right equipment.
This level of clarity is astounding.
niceguy71
Massachusetts
I sadly don't see many posts from @jcrmadden anymore???
hope he didn't give up on CB
EAFrizzle
"Sign in, please!"
SE de DFW
Hasn't posted since November of 25, last visited in January. Hope he's ok.
prcguy
My Anytone AT-5000 arrived late today as I was heading out to dinner with some family. I got a little time with it this evening doing a basic checkout then the wide band mod. Its easier to use than my Stryker SR-84HPC made by Anytone in the same form factor which is a 40W AM/FM radio and its single multifunction knob is annoying. The AT-5000 has up/down buttons which default to ch or frequency selection leaving the multi knob to default in volume mode. That's a much better setup than the Stryker.
Power out after the mod was around 32W SSB and 10W dead key AM with 40W peak with a loud voice. I forgot what FM was but you can select wide or narrow FM which is much better than being stuck with just narrow as on some models. I got a quick radio check on SSB and the guy said it sounded great, which needs to be further tested and verified, but its way better than the guy saying it was terrible. Didn't have much time to run the receiver through any tests but it sounds fine and has an easy to enable clarifier for SSB.
This is a lot of radio in a tiny package and its not very expensive. Mine came from Amazon but it shipped in a brown truck instead of the usual Amazon way, so it took a full week. If you're reading this you must have some interest, so stop procrastinating and just buy it.
prcguy
I spent more time with the new AT-5000 today and its a winner. Not the absolute best SSB CB I've had but certainly the best for the price and it has lots of great features. It made contacts all over the country and got great audio reports. The receive noise reduction works ok to the point I don't have to use squelch and it doesn't distort strong signals enough to worry about. One guy in Louisiana asked me what radio I was using and when I told him he said he's been on the fence about buying one and after hearing mine he is off to order his.
I need to try this in a vehicle as the channel up/down buttons on the mic and other easy to access buttons on the radio would make it a safe radio to operate while driving in my opinion.
niceguy71
Massachusetts
do you have a Anytone 5555 N II or Radioddity QT-60 ?????
I was just wondering how they compared????
... the size looks great but the radio just seems like it's not as easy or as good as the QT-60 or the smaller QT-80... just curious
prcguy
I have a 5555NII and it is a little better on receive and has more power on transmit but the 5000 sounds better on transmit using stock mics on both. I was using an external speaker on the 5000 due to its bottom facing speaker and having it sit flat on a shelf during testing. The 5555 sits in an angled mount which allows its speaker to face forward at an angle and that sounds great. I would say the internal speaker on the 5555 is also better. I have not tried them side by side but may do that later today.
WSAC829
Wisconsin Radio 225
EN64ak
Since the Aquario RP-70 apparently wont be exported outside of Brazil (according to their website), another company made a clone of it recently and i just ordered it. Should be here in the next 8-18 days. For $129 + $9 shipping i wasn’t going to pass it up.
WSAC829
Wisconsin Radio 225
EN64ak
AI noise reduction
From the internet:
Overview of AI Noise Reduction​
AI noise reduction utilizes advanced algorithms to enhance audio quality by distinguishing between desired sounds, such as speech, and unwanted background noise.
I assume it was just a fancy (or lost in translation) way of saying it comes with DSP/NRC.
KR4NIV
Asheville, NC
Yeah that's what I figured. I just have a pet peve about the use of term "AI" which is really just better algorithms & software, not "intelligence". 🙄
Nice small package, easy to squirrel away in a dash pocket or overhead.
niceguy71
Massachusetts
I was just talking about how CB's need a little help on the power... I was thinking somewhere around 8 watts.... I have helped a few people put in a Radioddity CS-47 with NRC.... it has 6.90 watts on AM and about 15 watts on FM ... the Radioddity seems to work pretty good with a great Stryker SR-A10 magnetic mount antenna and it's 6.90 watts... we got a good 7 plus miles on every install.... some times more like 9 miles depending on the conditions...... so this Luiton LT 310SDR with it's 7 watts AM /FM might just be the hot ticket for new users with small dash areas.
niceguy71
Massachusetts
looking at the specs of the Luiton LT 310SDR it say's 15 watts PEP?
if PEP is 4 times the dead key at 100% modulation... then the radio has a 3.75 watt carrier?
I also saw this saying it was an 80 channel CB? how do they figure that? 40 on AM and 40 on FM ???? most SSB radios show a 120 channel CB as it has 40 AM...... 40 LSB and 40 USB.... but this radio has FM.... so wouldn't it be a 160 channel CB and not an 80 channel???
going to be interesting to see how everyone likes it... this may become a very popular radio.. I have seen a lot of these Luiton radios ..a lot of the guys in my local CB group bought them because they were $49.99 .... several different models... all were terrible.. they had no receive at all... but of course the guys that bought these cheap radios also bought cheap antenna's.
looking forward to the "real reviews" from real users... hopefully a few guys in this group.
I see Simon the Wizard wants to make a video on that radio too... going to be a lot of interesting things to come out about it.
WSAC829
Wisconsin Radio 225
EN64ak
The above is a screen grab right from their website. I think it’s pretty obvious that it’s 80 channels.
Typical CB’s are normally 40 channels. 26.965 - 27.405. By default this radio goes up to 27.855 (which equals 80 channels).
After the jumper mod it unlocks the export mode for roughly 480 channels.
I always hated the “fake” claims of 120 channels when in reality most of those radios were just 40 channels with 3 “modes” consisting of AM/USB/LSB. Those aren't extra “channels” as claimed. You still operated on the same frequencies. Marketing gimmick if you ask me.
KR4NIV
Asheville, NC
I just contacted bestcbradio.com and asked them if they would send me one of these to do a video review on. We'll see what they say. If they do send me one. I'll do a complete on the bench review of all the features and how to use them and a real world install in a vehicle and test out on the open road. Should be fun. 😉
WSAC829
Wisconsin Radio 225
EN64ak
These are just rebranded Aquario RP70’s. Plenty of videos online going through the menus, export mod, on air tests, etc. However, the more videos the merrier. When mine arrives i’m just going to report my likes and dislikes of the unit. As we all know it’s on the slow boat to the states, so it could be a while yet.
Anyway, to tide you over, here’s some videos:
- YouTube
- YouTube
