- Joined
- Sep 2, 2017
- Messages
- 1
- Reaction score
- 0
OUTDOOR and complete VERSION 0.5-30mhz HF bands 20W HF Transceiver QRP SSB CW AM PTT Mic
Basic Specifications:
Frequency Range:
RX: 2.5—30MHz
TX: All HAM HF BANDS
Operating Mode: SSB, CW, FM, AM (RX Only)
Minimum Frequency Step: 1Hz
Antenna Impedance: 50ohm
Operating Temperature Range: -10℃ - +60℃
Frequency Stability:
±1.5PPM @ Power on 5 Minutes (Standard)
±0.5PPM if Optional TCXO Used
Operating Voltage: 9-15V DC
Operating Current:
RX: <450mA; Around 65mA after Power Off (Can be improved at5mA)
TX: Max. 3A(FULL Power),1.5A(5W Power)
Equipment Size: 190mm(W)﹡70mm(H)﹡40mm(D)
Packing Box Size: 245mm(W) * 125mm(H) * 80mm(D)
Transmitter Specifications
Frequency Band: 80-10m All HF Ham Band
TX Power: Standard 5W (13.8VDC),15W (FULL,13.8VDC)
Modulation Mode: SSB Software Balanced Modulation, 10KHz FM
AM Software Low Modulation (RX only)
Spurious Rejection: >40DBC
Carrier Rejection: >45DBC
Selectivity: SSB 2.3KHz (-6db)
CW 500Hz (-6db)
IF Frequency: 0
RX Sensitivity: >-115dBm
Dynamic Range: >95dB
RIT Frequency Tuning Range: ±1KHz
Audio Output: 8ohm, 0.5W
There are some videos about the operation of this machine on YouTube
https://www.youtube.com/watch?v=oLlWhmxCjI0
I attempt to describe them as accurately as possible.
IF YOU HAVE ANY ISSUES or QUESTIONS--- PLEASE FIRST CONTACT ME.
My e-mail:ulysses0902@163.com If you like it, contact me now!
Frequency Range:
RX: 2.5—30MHz
Operating Current:
CW 500Hz (-6db)
IF Frequency: 0
