First Mini SSB-capable CB
smithdoor
Clovis / California
In my testing, RX and TX range are comparable to every other radio i have around here when used on my base antenna. Mobile results regardless of what radio is being used are always going to be a mixed bag as there are just too many variables. Anyway, looking forward to your review of the rig when it arrives.
Today because all manufacturers use 4 watts (11-meter) it is the antenna that makes the difference.
I did test on the antenna I had on handed.
1) Rubber Duck no one on air
2) 50 inch on the handheld I got few
3) 98" tip antenna at 14 feet I did receive over 8 miles by cross street most would not reviled.
4) 18½ foot antenna to tip is 24½ feet real good at 20 miles again by cross streets. There was few that sounded great distances but again would not revile there cross streets. All was done about 10 AM on a sunny day
Dave
Echo4Thirty
Colorado Springs, CO
It arrived today. Holy crap is this thing small. First thing i noticed, it is slightly different than the RP-70. You don’t need to do the jumper mod at all. This radio doesn’t need to be opened. You hold the PTT and power on, then cycle through the 5 options consisting of BR, 10M, 12H, CB, and HF. Select what you want, then power cycle the radio. I choose BR as that's the normal 40 cb channels + 41-80 which is perfect for free banding, or listening to the nonsense on 27.425. I’ll be using this as a mobile and didn’t want to be bothered with changing bands. This mode gives me channels 1 - 80 without touching anything other than the channel knob.
The menu is simple with all the basic "set and forget" settings like mic gain, roger beep, NR level, backlight level, etc etc. The buttons on the face serve 2 functions. Tap for the first function, push and hold for the second function. Easy. The smartest thing they did was the “knob”. By default it changes channels. Push once and it adjusts volume. Push it again and it adjusts squelch. Push it once more to go back to channels selector. No menu needed to make those changes. RF gain is also as simple as press the RFG button for 2 seconds and adjust with the “knob”.
Only did brief “on air’ testing with my buddy 20 miles north of me. Barefoot on 38LSB i made the trip at s3-s4 with clean audio. He said it’s not loud, but not quiet either, and had no problem hearing me. He basically said it sounded “stock”, which it is. Stock mic, stock power. He also said it’s dead on frequency. We talked for about 45 minutes and it didn’t drift at all.
On the receive side it’s decent. I heard him fine, but his signal was a tad lower than he normally gives me on my other radios. There are 2 types of NR options. Standard, and AI. The AI NR is 10x better than the standard NR. The standard NR has a slight under water effect to it. Both work well knocking out the white noise though. Bonus: Dedicated NR button on the mic. Easy on, easy off.
The clarifier can be set for rx only, tx only, or both. It defaults to both (which i normally chose). Not really needed for general rag chewing, but handy to go in between channels, or fine tune people. Again, pretty easy. Push the CLA button and use the “knob”.
So far i think these are a steal at $129 for a mini rig with AM/FM/SSB. These do not have echo, ctcss/dcs, or weather band like the AT-5000, but they are also $50 less and a bit smaller in size. I’ll run this as a base station for the rest of the week and report back if i find any oddities or annoyances. I’ll probably toss it on the power meter as well and see what it does as it has 3 power options in the menu.
Edit: Mine did not come branded. The radio and mic are blank. I don’t mind this one bit. I’d rather it be unbranded for the cleaner look.
How did you cycle from 10M to the various options? mine is stuk on 10M and wont change to any other band,
WSAC829
Wisconsin Radio 225
EN64ak
With the radio powered off, press and hold the PTT on the mic and turn on the radio. Use the channel knob to cycle through the different options (BR, 10M, 12H, CB, HF). Choose which ever you want, then power cycle the radio.
Edit: When doing this you lose your settings (NR level, backlight color, etc etc) So pick a band and leave it to keep your settings.
Echo4Thirty
Ok that worked, in HF mode it took 12m away and it goes from 25.000 to 10M. Is that normal? I have not changed any jumpers in it.
WSAC829
Wisconsin Radio 225
EN64ak
Yep. Now you should have about 10 “banks” or “bands” of 40 channels in HF mode (A-J or similar). I personally used BR as thats CB 1-40 + 41-80. Perfect for my needs.
smithdoor
Clovis / California
Perfect. Thank you for your help. This thing is insane tiny! Perfect for what i need it for!
It why I stay with 11-meter. I turn it on and it is working. I on air to relax not being a programmer. Witch I do on computers I just want to relax.
Dave
FYI I get over 20 miles with portable antenna and relaxing anywhere I want . No hassling
niceguy71
Massachusetts
Fits perfect in a rental car with a President Virginia on the roof
great picture.... it's just hard to believe how small it is... but that picture sure makes it look small
I'm thinking of putting SSB in my friends Jeep so we can ?maybe? make the 18.50 miles from our two house's
I'd buy it if it had a little more power.... the incredibly tiny Radioddity CS-47 that I have in his Jeep now puts out 6.90 watts on AM .... because it's so small and it's almost twice the legal limit I thought it was enough... fits in any vehicle as it mounts behind the seat of a pick up or under the seat of any vehicle with all the controls on the mic...
but after talking to several of my friends with 10 watt radios... it's a noticeable difference... so I'd just like a little more power... the CS-47 does 15 watts on FM and on FM we talk a long long ways away..... it's actually amazing to talk so far away on FM... but it's that 15 watts output power
my friends all like and try to stay on AM... and the 6.90 watts on AM just isn't cutting it when you look at the Anytone 5000 with somewhere around 30 watts on AM
so I'll spend a lot more for the Anytone 5000 ....
with that said... how can you complain about that little itty bitty radio with over 4 watts and with side band for $129 bucks.... it's truly an impressively small radio
PAN-Crusader
Munich, Germany
This tiny cb radio is not a performer for AM. There are other rigs. This is the smallest SSB Export radio ever! 12 Watts is a good valiue for DX
niceguy71
Massachusetts
Have you tried it Pan-Crusader???
Always nice to get reviews from people that have tried it.
I think it's over 4 watts on AM... I think it's 6 or 7 watts. So it should perform as good if not better than a stock CB
And I believe it's 15 watts on SSB
It might work really really good??
WSAC829
Wisconsin Radio 225
EN64ak
The AI Noise Reducrion is very good, but if it is switched ON there is no modulation and no TX on SSB!
Yeah, its a software bug. It will work on SSB, but you have to set it, then disconnect power (not power off), then reapply power and turn it on. It’ll work then. The AI NR is wild. It works on both RX and TX. It only picks up your voice on TX. If you whistle, or take a deep breath it ignores it. Pretty cool stuff.
makerdino059
Asheville, NC
I'll do a "range test" when I get mine but there are many variables involved. I could do a "range test" one day and do the same test on a different day and get different results, better or worse. I'm more concerned with noise reduction, clarity in TX/RX and ease of use. It's a radio with few buttons and sub menus so it's more about get the settings dialed in and don't fret too much about trying to change too many things out on the road. Just learn where you want the default function to be on the menu and leave it there i.e. RFG or NR level.
It's so tiny that I'm going to mount it overhead between the sun visors in my Eurovan. We'll see how effective the down firing speaker is. I'm gong to remove the QT60 and install it in my 99 Pathfinder. I'm also converting the Stryker SR-A10 antenna from a mag mount to a through hole solid mount for a better ground plane effect.
Factory setup out of the box it's an 11 meter radio, 40 channels with SSB so 40 LSB, 40 USB, plus FM & AM so the call it "80 channel". I've seen that it can be jumper modded to cover 10 & 12 meter but I'm going to just leave it as... for now. After I get my ham license I'll probably do the mod.
Tracking update shows carrier has the radio enroute from PA. Should have it in a few days. ;)
makerdino059
Asheville, NC
Specs from webpage: SSB: 15W, FM: 7W, AM: 7W (Avg), PEP: 16W
K6GBW
Montebello, CA
Man, that thing is so tiny. It tempts me! I could actually fit that in my Subaru Crosstrek and put a Laird NMO-27 on the roof. Even if it didn't transmit more than a few miles it would still be useful to me. I travel a lot and just being able to listen would be both informative and just pure entertainment. I look forward to more reports on this little guy.
