SLERS2 site 17 "Orlando Air" is now reporting sites 11, 13 and 15 as neighbors (with the new 9254A.141 sys ID)
it is my belief (without any facts to support it) that this is the first phase in of "SLERS 2" - and I think at some point as the old EDACS SLERS sites are converted, they will become part of the (new) phase 2 141 system.Is FHP as a whole going to be moving to this system? Like road patrol/ground operations, not just air ops
pls submit that to the db:Key West, Monroe County
769.19375c
SYS ID 141
RFSS 27
Site 27
WACN 9254A
Did you catch the Nac and NL?Key West, Monroe County
769.19375c
SYS ID 141
RFSS 27
Site 27
WACN 9254A
769.19375 cc 769.44375 769.69375 769.94375 |
Site 21 might be Perry? Anyone in that area can confirm it?
21:11:44 Sync: +P25p1 nac: [ D9] src: [ 0] tg: [ 0] TSBK
Network Status Broadcast TSBK - Abbreviated
WACN [9254A] SYSID [141] NAC [0D9]
Frequency [769.193750] MHz
21:12:04 Sync: +P25p1 nac: [ D9] src: [ 0] tg: [ 0] TSBK
RFSS Status Broadcast - Implicit
LRA [15] SYSID [141] RFSS ID [021] SITE ID [021] CHAN [101F] SSC [60]
21:12:03 Sync: +P25p1 nac: [ D9] src: [ 0] tg: [ 0] TSBK
Secondary Control Channel Broadcast - Implicit
RFSS[021] SITE ID [021] CHAN1 [1047] SSC [04] CHAN2 [106F] SSC [04]
Frequency [769.443750] MHz
Frequency [769.693750] MHz
21:15:30 Sync: +P25p1 nac: [ D9] src: [ 0] tg: [ 0] TSBK
RFSS[021] SITE ID [021] CHAN1 [106F] SSC [04] CHAN2 [1097] SSC [04]
Frequency [769.943750] MHz
21:15:33 Sync: +P25p1 nac: [ D9] src: [ 0] tg: [ 0] TSBK
RFSS[021] SITE ID [021] CHAN1 [1097] SSC [04] CHAN2 [1047] SSC [04]
21:13:13 Sync: +P25p1 nac: [ D9] src: [ 0] tg: [ 0] TSBK
Adjacent Status Broadcast - Abbreviated
LRA [17] RFSS[023] SITE [023] SYSID [141] CHAN-T [1023] SSC [60]
Up to Date (Correct) Valid RFSS Connection Active
Frequency [769.218750] MHz
LRA [13] RFSS[019] SITE [019] SYSID [141] CHAN-T [10C1] SSC [60]
21:15:42 Sync: +P25p1 nac: [ D9] src: [ 0] tg: [ 0] TSBK
LRA [0F] RFSS[015] SITE [015] SYSID [141] CHAN-T [10BD] SSC [60]
Frequency [770.181250] MHz
21:15:50 Sync: +P25p1 nac: [ D9] src: [ 0] tg: [ 0] TSBK
Identifier Update (8.3.1.23)
Channel Identifier [1] BW [68] Transmit Offset [0978]
Channel Spacing [032] Base Frequency [092ACD40] [769000000]
21:15:46 Sync: +P25p1 nac: [ D9] src: [ 0] tg: [ 0] TSBK
Identifier Update for TDMA - Abbreviated
Channel Identifier [9] Channel Type [3] Transmit Offset [32C0]
21:15:47 Sync: +P25p1 nac: [ D9] src: [ 0] tg: [ 0] TSBK
Channel Identifier [8] Channel Type [3] Transmit Offset [1C20]
Channel Spacing [032] Base Frequency [0A250BC0] [851000000]
Looks like the control channel I had changed. When I was by Citrus County I was picking 21 up with 769.44375. Is the NL 15 19 23 25?I think I can confirm it now, signal is pretty bad, but just good enough to decode some of the control channel. This is a dump of relevant information on that site.
Code:21:11:44 Sync: +P25p1 nac: [ D9] src: [ 0] tg: [ 0] TSBK Network Status Broadcast TSBK - Abbreviated WACN [9254A] SYSID [141] NAC [0D9] Frequency [769.193750] MHz 21:12:04 Sync: +P25p1 nac: [ D9] src: [ 0] tg: [ 0] TSBK RFSS Status Broadcast - Implicit LRA [15] SYSID [141] RFSS ID [021] SITE ID [021] CHAN [101F] SSC [60] Frequency [769.193750] MHz 21:12:03 Sync: +P25p1 nac: [ D9] src: [ 0] tg: [ 0] TSBK Secondary Control Channel Broadcast - Implicit RFSS[021] SITE ID [021] CHAN1 [1047] SSC [04] CHAN2 [106F] SSC [04] Frequency [769.443750] MHz Frequency [769.693750] MHz 21:15:30 Sync: +P25p1 nac: [ D9] src: [ 0] tg: [ 0] TSBK Secondary Control Channel Broadcast - Implicit RFSS[021] SITE ID [021] CHAN1 [106F] SSC [04] CHAN2 [1097] SSC [04] Frequency [769.693750] MHz Frequency [769.943750] MHz 21:15:33 Sync: +P25p1 nac: [ D9] src: [ 0] tg: [ 0] TSBK Secondary Control Channel Broadcast - Implicit RFSS[021] SITE ID [021] CHAN1 [1097] SSC [04] CHAN2 [1047] SSC [04] Frequency [769.943750] MHz Frequency [769.443750] MHz 21:13:13 Sync: +P25p1 nac: [ D9] src: [ 0] tg: [ 0] TSBK Adjacent Status Broadcast - Abbreviated LRA [17] RFSS[023] SITE [023] SYSID [141] CHAN-T [1023] SSC [60] Up to Date (Correct) Valid RFSS Connection Active Frequency [769.218750] MHz 21:15:30 Sync: +P25p1 nac: [ D9] src: [ 0] tg: [ 0] TSBK Adjacent Status Broadcast - Abbreviated LRA [13] RFSS[019] SITE [019] SYSID [141] CHAN-T [10C1] SSC [60] Up to Date (Correct) Valid RFSS Connection Active 21:15:42 Sync: +P25p1 nac: [ D9] src: [ 0] tg: [ 0] TSBK Adjacent Status Broadcast - Abbreviated LRA [0F] RFSS[015] SITE [015] SYSID [141] CHAN-T [10BD] SSC [60] Up to Date (Correct) Valid RFSS Connection Active Frequency [770.181250] MHz 21:15:50 Sync: +P25p1 nac: [ D9] src: [ 0] tg: [ 0] TSBK Identifier Update (8.3.1.23) Channel Identifier [1] BW [68] Transmit Offset [0978] Channel Spacing [032] Base Frequency [092ACD40] [769000000] 21:15:46 Sync: +P25p1 nac: [ D9] src: [ 0] tg: [ 0] TSBK Identifier Update for TDMA - Abbreviated Channel Identifier [9] Channel Type [3] Transmit Offset [32C0] Channel Spacing [032] Base Frequency [092ACD40] [769000000] 21:15:47 Sync: +P25p1 nac: [ D9] src: [ 0] tg: [ 0] TSBK Identifier Update for TDMA - Abbreviated Channel Identifier [8] Channel Type [3] Transmit Offset [1C20] Channel Spacing [032] Base Frequency [0A250BC0] [851000000]
Only ones I saw were 15, 19, and 23. Didn't see 25 in the adjacent sites, but signal was poor, so it could have been there, just didn't see it.Is the NL 15 19 23 25?
