Florida SLERS (EDACS, P25 197.9254A and P25P2 141.9254A)
bravo14
Polk County FL
I was at Belle Glades today and tried to catch the site 138 lcn 5. I can't find any where. I even had all freqs for that site/location. Guessing using another county/site freq? I even couldn't nothing on S105 S Miami area. I even went south of sr41.
bravo14
Polk County FL
Sites Unkown where the tower is located.
1 Big Bend area
3 Big Bend & SW area
4 Big Bend area
5 Big Bend area
82 Big Bend area
255 Big Bend area
255 SR29 & I-75 is correct for that area.
Not sure if 255 is statewide or region areas.
Site 107 & 162 still needs to be worked on to confirm correct sites & lcns.
Jasper (Hamilton County) same setup as site 62?
International Speedway has anyone confirm as site 223 & LCNs? (Only in use when racing is going on)
Ponte Vedra (Only when TPC *The Players Champion or big event going on)
Site 59 on my last visit around that area unitrunker showing lcn 11 19 22
Site 140 on my last visit around that area unitrunker showing lcn 8 19
Site 214 on my last visit around that area unitrunker showing lcn 8 19
SIte 236 on my last visit around that area unitrunker showing lcn 8 19
  • FL SLERS 800 Edacs 5 7 24 1235.pdf
bravo14
Polk County FL
Today went to dixie & levy counties and got 3 sites.
Site 107 162 230 has been submitted. Site 107 162 were not in order and wrong locations. This pdf been updated.
  • FL SLERS 800 Edacs 5 8 24 1738.pdf
bravo14
Polk County FL
Here is a update on Tg's.
  • FL SLERS 800 Edacs 5 22 24 0024.pdf
bravo14
Polk County FL
I ran Unitrunker for 2 days and got a bunch of patches.
  • FL SLERS 800 Edacs 5 25 24 1150.pdf
batdude
Florida Db Admin / Florida Forum Moderator
Moderator
East Central, Florida
It looks like the conversion of the current P25 Phase 1 system has started.
The Orlando Air site (RR Db entry here) is now broadcasting as WACN 9254A, but the sys ID is now 141 and the Site # is 17 with a NAC of 0B1.
Start taking a listen to and submit to the RR dB!
bravo14
Polk County FL
Interesting I Thurs I drove through Flagler Voluisa and i4 til Polk County no new P25 showed up. I noticed on the screenshot it says 9254a.141 the RRDB shows 9254a.197
bravo14
Polk County FL
Here is a pdf file I found awhile back. I don't remember where I found it at.
  • 700 mhz state use channel matrix.pdf
wsmoore
Jacksonville,Fl.
Has anybody heard any CC or voice activity on the New SLERS-2 P25 Phase 2 System? Also has anybody heard if the State will be using the P25 Phase 2 Control Channel on the system? Knowing Florida I'm sure they will.
bravo14
Polk County FL
Here is a forum for central fl area. Florida SLERS P25 updates appear to have started
2 weeks ago I didn't see nothing from polk to baker county. Appears there will be sysid 141 instead 197?
wsmoore
Jacksonville,Fl.
Ok thanks for that info! I haven't heard anything up here either. Imagine that they are behind schedule I wonder if they have ever finished installing a system on time!
trooper890
N/A
Phase II control channel is an L3 only feature, you wont see that on the new system.
batdude
Moderator
NOTE: This thread has been changed to capture the new P25 Phase 2 transition of the SLERS system. Please keep ALL SLERS posts in this master thread - makes it a lot easier for people to find information.
The new system ID (141) has been added to the database:
Statewide Law Enforcement Radio System (New) Trunking System, Orlando, Florida
Site 17 (orlando) is reporting a neighbor site of 11 on 769.69375 - I would guess that this is the Stuart, FL site.
Also note that the Orlando site is using the same frequencies as before.
seagravebuff60
Short Bus Reject
Wouldn't having the 2 Systems under one Database entry be easier than having two separate listings?
I get that the Phase 1 System is 9254A.197 and the Phase 2 system is 9254A.141. But we could watch the upgrade to P2 in one DB entry. It seems like having two separate entries in the DB is adding more work.
batdude
Moderator
If I understand the limitations of the RR dB correctly, that’s not possible. A new SysID is a new RR dB unique identifier….. the key right now in my mind is for those across the state to start listening to (DSD+ / Unitrunker) on the existing .197 sites to see when they switch over so they can be added to the new .141 system.
Side note: I have seen unencrypted comms on .141. YMMV
seagravebuff60
Short Bus Reject
I think adding Multiple WACNs and system IDs to one system is possible in the RR DB. I'm not sure if these systems are linked via ISSI or whatever, but still. There is a system here with two separate system IDs, and I'm not sure if it is linked via ISSI or if it is one Database entry. Take a look here: Metro-25/MTA MRRS Trunking System, Regional, New York
My point is, if 141 is replacing the 197 system, wouldn't it be more accessible (for DB admins and us users) to have one SLERS system in the Database and define the two separate IDs in one entry. Then, when all the sites get "pealed" off the 197 system and added to the 141 system, you can delete the entry of the 197 completely, and SLERS will now be a 141 system. Both systems would be defined under one single entry in the DB until 197 is decommissioned. So that we can actively track the progress under one entry rather than have to pull up 2 DB entries simultaneously. It just makes my life more sense to me that way.
I may not be explaining this 100% right, but this is a chart that I made last night to describe what it would look like: 1730125950774.png
To my knowledge, the system is just upgrading from Phase 1 to Phase 2 and keeping all the existing Talkgroups and RIDs. It's just the System ID and Site IDs that are changing, right? So, instead of duplicating all the TGs in the database, wouldn't it be easier to update the sites? Also, since the Wiki is hard coded into the DB, wouldn't there be 2 Wiki entries?
bravo14
Polk County FL
on site 17 I’m locked in and site 11 freq is 769.69375 not sure where that is located at. Tg 60291 popped up.
Tg 17 popped up 13:34 shows ENC
