ampulman
Background: Have a 4 tube fixture w/2 ballasts, which for quite a while, would only light (with difficulty) 2 tubes.
When cooling season would arrive, and line voltage would drop, it would be difficult, and sometimes impossible to light the 2 tubes.
Even so, in this condition, no interference problems were noted.
I finally bit the bullet and bought 2 ballasts and replaced them.
The fixture now works perfectly (all 4 tubes light instantly), but have noticed a problem.
I can be listening on my Walk Man, when suddenly the audio will be overcome by a constant buzz, making listening difficult to impossible.
If I flick the switch off, then immediately on, the buzz is gone. I'm not absolutely sure, but I think it only occurs when listening to a distant (weaker) station.
I attribute this to the ballasts as there are no starters, unless they are incorporated into the ballasts (doubtful).
I'm wondering if there is any way to eliminate this, such as by installing a capacitor across the power line, or looping the hot and neutral lines around ferrite rings? Space is somewhat limited, but I think it could be done.
Thanks for listening.
Amp
Amp
