DSDPlus FMP24, NXDN96, and rotating control frequencies
Reconrider
Inside the Galaxy
Radio Galaxy
I feel like I had a similar quirk with even the five second intervals, so I will keep a watch on it and may expand it to a bit longer. Once everything is running, it runs amazingly well, but getting there is 99% of the battle! :ROFLMAO:
i think i wait a good 12 seconds before the next one runs. Thats giving me extra leway being smart lol
LimaZulu
That .bat file is great for a single-dongle setup; thank you!! I should have clarified that the .bat file I posted is intended for use as a single file; manually opening four files for my dual-dongle setup was tiring, so that one .bat file opens them all in sequence. I wasn't sure if each app needed a bit of breathing room between opening, but I may lower the number of seconds and check my results.
Thanks again for your help!!
What you did is not wrong, it's just a bit harder to edit if you need to because you have to edit 4 different files to make any changes to your setup. Putting them all together in one file makes changes a bit easier.
No matter if you do single ot two dongle setup. You can do it both ways - yours and mine. Just whatever is easier for you.
I was using timeout as well in the beginning but now I only do 1 second timeout between fmp and dsd startup as I found that's what works best and fast :)
