Both sites that you refer to in the database (Fort Worth Layer 1 and Fort Worth Layer 2) simulcast on those frequencies from 6(I think) different physical and geographically different sites, see the locations in the thread: http://forums.radioreference.com/te...altom-city-watauga-rh-went-digital-today.html
The Northeast Tarrant "site" actually transmits on the same frequencies at 3 different locations as well.
The same goes for Johnson County(I think 3 or 4 physical locations). I'm not sure about Mansfield(I think it's two physical sites). The Texas Motor Speedway site is just one physical location. However, some of the talkgroups might be carried on Fort Worth Layer 1 or 2. It is confusing.
Bottom line, a "site" in the database that you referred to does not necessarily mean a single physical site. Looking at the site map can help, but those are not always accurate, as in this case.
Site Map: Fort Worth Regional Radio System Trunking System, Tarrant, Johnson Counties, Texas
I hope that helps.
I hope that helps.
Um, don't look like it to me?
Fort Worth Regional Radio System Trunking System, Tarrant, Johnson Counties, Texas - Scanner Frequencies
Am I missing something?
Unless you're use is mobile, you should program your scanner to only use one site.
