Anyone use a frequency counter hooked up to an outside antenna to see what is active in your area? Looking at a surecom SF-103. If there is a better way, feel free to comment. Thanks.
Spectrum analyzers are to expensive for my small hobby. But if you ever get a chance to hook your similar model up to an external antenna, be interesting to see the results. I live out in the boonies so not close to any antennas.Spectrum analyzers and SDR dongles work great to check activity on the bands as you get a panoramic view of a slice of the spectrum. With the appropriate software the RTL-SDR dongle displays a waterfall in addition.
As for the Surecom SF-103, I have a similar model that covers from 50 megs and up. Never tried hooking it up to the outside antenna so not sure how it'd work. But best way to find out is to try. Guess it would all depend on the strength of the signal (s) and the gate time.
SDR with appropriate software would be my choice.Anyone use a frequency counter hooked up to an outside antenna to see what is active in your area? Looking at a surecom SF-103. If there is a better way, feel free to comment. Thanks.
Not for anywhere close to the price. It's by far the best value for the money out there.Amazon.com: RTL-SDR Blog V3 R820T2 RTL2832U 1PPM TCXO HF Bias Tee SMA Software Defined Radio with Dipole Antenna Kit: Electronics
Buy RTL-SDR Blog V3 R820T2 RTL2832U 1PPM TCXO HF Bias Tee SMA Software Defined Radio with Dipole Antenna Kit: Radio Antennas - Amazon.com ✓ FREE DELIVERY possible on eligible purchaseswww.amazon.com
Looking at this one but see it goes up to 1.7 Ghz. Is there a better one that goes a bit higher?
