Frequency counter
bearcatrp
Land of 10,000 taxes
Anyone use a frequency counter hooked up to an outside antenna to see what is active in your area? Looking at a surecom SF-103. If there is a better way, feel free to comment. Thanks.
nd5y
Wichita Falls, TX
You want a spectrum analyzer for that, not a frequency counter.
If you are near a lot of equally strong signals then a frequency counter will just display garbage.
Xray
You will get absolutely no joy hooking a gadget like that up to an antenna - Same story 20 years ago. But hey give it a try, whats the worse that can happen ?
spongella
N2HUN, Western NJ
Spectrum analyzers and SDR dongles work great to check activity on the bands as you get a panoramic view of a slice of the spectrum. With the appropriate software the RTL-SDR dongle displays a waterfall in addition.
As for the Surecom SF-103, I have a similar model that covers from 50 megs and up. Never tried hooking it up to the outside antenna so not sure how it'd work. But best way to find out is to try. Guess it would all depend on the strength of the signal (s) and the gate time.
Shards
Denver, CO
I use a frequency counter, and it’ll read frequency plus DCS/CTSS codes. But you have to be typically a foot or so from a transmitting unit. It won’t work from afar.
bearcatrp
Spectrum analyzers are to expensive for my small hobby. But if you ever get a chance to hook your similar model up to an external antenna, be interesting to see the results. I live out in the boonies so not close to any antennas.
a417
spectrum analyzers are too expensive for many of our small hobbies, and even some of the larger ones. A $20/unit SDR can perform admirably on a spectrum survey basis for the casual user, and will only become a more powerful tool as you learn how to use it.
bearcatrp
Am currently looking into one. Reading the forums to figure out which one to order. Trying to figure out the free software packages.
jonwienke
More Info Coming Soon!
VA
SDR# is probably the easiest, and works well.
slicerwizard
Toronto, Ontario
SDR with appropriate software would be my choice.
A bit over a year ago, Brockville Ontario PD moved from analog VHF to parts unknown and there was no real movement on finding them for a couple of weeks: Brockville Police is silent? New system?
Parked by the cop shop and ran DSD+'s spectrum survey for an hour or so. Didn't know if they were still on VHF - figured they could be anywhere - so had it sweeping 139-999 MHz. It found strong signals on 465.9875; monitoring the repeater output on 460.9875 showed DMR RAS AES voice calls - not your typical business traffic. Found matching transmissions on 451.4750 and managed to locate the 460.9875 transmitter at 32 Wall Street, home to a bunch of government offices. Done and done.
"Surecom SF-103 The frequency meter capable of measuring the parameters of the frequency of the continuous carrier signal walkie-talkies..." - so it wouldn't have even detected the TDMA transmissions from the DMR subscribers at the cop shop...
bearcatrp
a417
At the <30% price point? Not that i'm aware of. What do you need above 1.7Ghz? You are now in HackRF territory, etc.
jonwienke
VA
Looking at this one but see it goes up to 1.7 Ghz. Is there a better one that goes a bit higher?
Not for anywhere close to the price. It's by far the best value for the money out there.
bearcatrp
Will order that to give it a try. The ones I found that go up to 3 ghz starts around $100 and goes up. I looked at the free software for these SDR's. Is there a preffered one over another or a recommendation? Thanks.
a417
...well....how much do you want to spend?
a417
Thats the ticket. Start small, figure out what your needs are. If you don't need to TX with it, and are staying below 1.6Ghz, you're golden.
