FTH-2070 Programming issues..
I have a pair of FTH2070 radios here that are giving me programming issues. I have two versions of software, on the older version as as I am in the window to download and hit the "Mon" button to put it in RX I get ERR1. The newer version of software is 1.60 and I get to the window to download and hit "mon" and it goes to RX and then after downloading it gives the ERR1. Have you had any experience with this problem? Is it a software issue? Or a com port speed issue??
10-95
Problem Fixed! Software version issue...
m1bpt
Stockport UK
Help required to reprogram FTH-2070
I have just purchased a FTH2070 and would like information on what is required and any known bugs when re-programming such as what platform , speed and software versions are needed. Kindest Regards Paul M1BPT
USP45
I have an FTH2070 and at turn on it shows ERR2. The radio will go into test mode when pressing PRI and turning it on, showing a flashing TXRX but it wll not accept any commands when I try and write to it. My software version is 1.62, any ideas on how to clear it? Any suggested gurus that I can call or email to help me out? Thanks a lot--
s56ips
same problem
i have two fth-2070, programing box FBR2070 - same broblem - ERR1
version of my software is 1.51.....
helpppp...
s56ips
samo
