ProScan: Full Screen
Gill122
Is there anyway to make the detached scanner window full screen on the monitor? Or any other view options that will go full screen?
Gill122
I tagged it with the Proscan header... Maybe some suggestions for a first time poster would help? Thanks
ProScan
Software Provider
Ontario, Calif.
The size is what it is. If you want the virtual scanner full size then use the Web Server feature. The Web Browser page containing the virtual scanner can be resized
Gill122
Thank You!
iMONITOR
Silent Key
S.E. Michigan
Yes there is. Lower the resolution on the video settings on your monitor. The lower the resolution the larger the scanner display will become. Try 1024x768 for example, although that may be too big. Experiment to find what you're looking for.
ProScan
Software Provider
Ontario, Calif.
That is one way it should work. Here's another using the Web Server feature and a Web Browser.
75208
