G4 not muting
w2lie
New York DB Admin
Long Island, NY
amys17
East Sparta, Ohio
Agree with above. It is probably your settings for the reset or you have alternatives enabled in the sub group.
For resetting to mute it after dispatch, use an auto reset or selective timeout reset. Both will reset without you needing to do anything. One is automatic after dispatch, the other monitors for a time period after dispatch then resets.
Alternatives Box in the sub group means the Isherwood will not just listen for tones. It's listening for tones to open the speak ER during dispatch or any push to talk voice traffic
RouterRooter
It's most likely your settings. Can you take a snapshot of the Zone/Key config window for the position that is not muting after the tone activations?
Also, need a snapshot of your Binding Config if this is a talk group activation.
If you haven't used it for your programming, figure 11 on this chart might help you out
Hello, thank your the quick answer to my call for HELP
Here are snapshots of the zone/key config windows and binding config.
When the dispatch ends the pager stays open (unsquelched) for 4-8 seconds and I can hear traffic.
According to what I read under Automatic Reset the pager should mute (squelch) after the dispatchers carrier drops.
OK
Here are snapshots of my zone/key config windows and my binding config.
As I understand it, in Automatic Reset when the dispatcher's carrier drops the pager must mute.
Mine does not.
I continue to hear traffic for 4-8 seconds.
help.
RouterRooter
Thank you for the quick answer to HELP ME
For 2 years now I have tried every combination possible.
The pager does not mute (squelch) after the voice announcement ends and the dispatcher's carrier drops.
The pager stays open a few seconds and I can hear other traffic.
I do not want this.
I have tried auto reset and the pager still remains open (un-squelched) for a few seconds.
I do not have alternatives checked.
HELP
I
