G4 Rebooting Itself
mswells
WB6JLB
Phoenix, AZ
My G4 has decided to constantly reboot itself, after one transmission. Any ideas ? I downloaded the pps file from the unit, and reloaded it again, but still getting reboots.
MaximusTheGreat
Perhaps if you help us out with what versions of the pps and firmware you currently have on it, would help us troubleshoot it for you.
JD21960
ILL-annoyed
G4 Reboots
My G5 did that when my original battery was finished. I just got a new battery
mswells
WB6JLB
Phoenix, AZ
Still getting the constant reboots, even after updating to the latest firmware, and the latest pps. Tried removing the battery for awhile, and same problem still....also tried reloading the profile from the updated pps.
T-Santon
Ohio's Snow Belt
The only thing left that I can think of is to try a make a completely new profile from scratch... And if the problem still persists, then it may need to be sent in for repair. :(
Or like Johnnydollar2 said, it may just be time for a new battery.
David628
Colorado
Not sure if this would work or if it’s even safe to do so others please chime in. This is strictly just a random thought, but can you take out the battery and plug the original G4 USB/plug into it and try to power it up? This would rule out if it’s a battery issue?
Sent from my iPhone using Tapatalk Pro
