G5 Alert Tones with Patched Talkgroups
aaknitt
I'm trying to configure a Unication G5 on a system that uses TGID paging to work with TwoToneDetect by using custom alert tones. This works fine for a single talkgroup. I enable Voice Buffering and a custom alert tone that's a WAV file of a two-tone page. The voice dispatch is buffered and plays after the custom alert tone. Works great.
I had expected that when multiple TGIDs are patched together (supergroup/system patch) to page multiple FDs that the alert tones for all TGIDs in the patch would play sequentially, followed by the buffered voice. That doesn't seem to be happening. I'm trying to figure out if I have something misconfigured or if the pager doesn't support this behavior.
Behavior currently seems to be:
  • If I have all talkgroups in the patch assigned to the knob position, only the custom alert tone for the "supergroup" in the patch plays
  • If I have only a single talkgroup from the patch assigned to the knob position, the custom alert tone for that talkgroup plays (even if it's not the supergroup - i.e. the patch is being detected and followed)
Is it possible to do what I'm trying to do?
I'm testing on a Motorola system. I've seen a lot of messages on this forum related to a Harris patch "bug" of some type but I'm not sure I understand what that issue is. If I can get this to work on a Motorola system, would it also work on a Harris system?
@aaknitt you might want to look at this thread not sure if @jake_Braker got it working
aaknitt
Hmmm....not sure that's the same issue. In my case, the pager does alert, but it only plays an alert tone for one of the talkgroups in the patch. I was hoping it would play the alert tones for all talkgroups in the patch, but not sure if that's possible or not.
