G5 error message
911ert
Sheboygan WI
I ran into this recently and had a bit of an issue getting it cleared out. Any ideas why it happened?
Sent from my iPad using Tapatalk
cpetraglia
Fairfax, VA
There have been a few here with that error message. We have appealed to Unication for an explanation with (To the best of my knowledge) no answers. Their is much speculation it is from trying to use Monitor Mode when their may be some PII TGs coming thru. I was in MM when it happened to me. Once I turned it off, it never happened again.
911ert
Sheboygan WI
I believe I was monitoring as well when it popped up. That DVR button threw me a bit.
911ert
Sheboygan WI
I had to do a reset as they indicated on the screen. Turning it off wouldn’t clear it. No clue what caused it but it hasn’t come back yet.
OregonScanner
My brand new G5 UHF just did this. Put the battery in the unit, charged it with the free desktop charger, programmed it up, then the third or fourth time the unit turned on I get this error message.
At the top of the screen right before the message popped up the unit flashed "Stopped Charging" even though it was not on the charger before I turned it on. Also it said "Charging Error (11)" or "Charging Error (22)" I can't remember.
Now it is showing the same error message as the picture in the first post.
It says press reset + DVR + play for 3 seconds to reset. I know the reset button is on top of the selector knob and the play key is the top button on the side of the pager. What is DVR?
I've had a G4 since 2016 and never had this on the G4.
OregonScanner
Ok. I think the DVR key is the small button on the side of the unit. Pressed all 3 and reset the unit. So far so good.
OregonScanner
Once when I turned the unit on after it had been reset earlier I got the post-programming screen. It said Unication Digital Paging www.uni.com.tw with the little dots on the bottom of the screen. Same screen that shows up right after the unit is programmed. Then it works. Only happened once.
911ert
Sheboygan WI
I have had communication from a tech at Unication and he said it is a known issue and the unit needs to be replaced.
911ert
Sheboygan WI
Sounds like there are quite a few that need to be replaced then
Yes could very well be. It hasn’t happened again I’m just glad they are replacing it.
IAmSixNine
Dallas, TX
Week or so ago my G4 had this issue. Since i wasnt able to figure out the keys needed i did a battery pull.
Can someone confirm what the key sequence is for a soft reset?
L
Legend2010
Guest
Press the two side buttons and the top playback button for 4 seconds and the pager will do a a hard reboot.
911ert
Sheboygan WI
I can tell you I was able to clear it. I was told by Unication it needs to be replaced. I had it swapped as it’s a known issue.
IAmSixNine
Dallas, TX
So they think its a hardware issue?
I shut both my G4 off when go to bed at night. Turned both on this morning and 1 rebooted back to the unication screen and the other showed that message. And since i cant ever get they key combo right i did a battery pull.
Starting to think i should never turn them off. LOL
mdsxfire
EDBM
Uxbridge, north of the river Thames
Does this happen randomly or when powering on or when left on for extended periods or just whenever. Just wondering if there is a specific issue it would do this. I thought I remember reading a post a little bit ago that stayed it might be a phase 2 transmission that somehow trips it?
IAmSixNine
Dallas, TX
only happens for me when i have had the units off over night.
I tested for a week by leaving them on and never had an issue.
